should all the words on the steering wheel buttons be lit?
Old Sep 7, 2010 | 10:14 PM
kthai417's Avatar
i dont think this is normal, but the words on my steering wheel buttons are not lit up when i have my headlight on at night. is this normal? or the light or fuse broken?
Old Sep 7, 2010 | 10:24 PM
HondaOnWORKS's Avatar
Je t'aime...
If I'm reading this correctly to my understanding... All the lights on the steering wheel should be lit up for night time use.
Old Sep 8, 2010 | 01:32 AM
Flyer92's Avatar
The majority of mine aren't.... I can't even begin to wonder how about fixing it myself without having to take it to the stealership...er...dealership.
Old Sep 8, 2010 | 06:35 AM
Mjakaz09TL's Avatar
Plan on removing the airbag.. do it yourself and save your money, very easy. Unplug battery for 5 mins then pop small access cover under steering wheel/airbag and disconnect airbag connector and ground. Then remove 2 Torx head screws on sides. You can have it off in 5 mins.
Old Sep 8, 2010 | 09:03 AM
quake97's Avatar
I was actually wonder the same thing. My cruise button doesn't light up. It's not worth fixing in my opinion. If others go, I'll think about it.
Joe
Old Sep 8, 2010 | 09:10 AM
Dan1629's Avatar
Registered Member
I went out and looked at my car. Yes all the switches/words light up.
Old Sep 8, 2010 | 09:18 AM
dwb993's Avatar
Section G of the 3G Garage has complete instructions on replacing these lights with LEDs. Take a look and see if it is something you think you can tackle yourself. While it is fairly easy to do, there are some more details to be considered than just "Unplug battery for 5 mins then pop small access cover under steering wheel/airbag and disconnect airbag connector and ground. Then remove 2 Torx head screws on sides. You can have it off in 5 mins."
Knowledge is power!
Old Sep 8, 2010 | 02:16 PM
dadon's Avatar
i was going to do this myself but went to the dealer and said "I read on azine that it was covered by warrenty" and he said "yes it is"
so the dealer replaced them and washed the car (handwash) for FREE
Old Sep 8, 2010 | 02:34 PM
TLTrance's Avatar
AVB for President!
Be careful about this one... I found out (the hard way) that the extended warranty (past the original 4yr, 50K miles) does not cover anything that is trim related, and does not cover blown bulbs...
Old Sep 8, 2010 | 02:55 PM
dadon's Avatar
ahh just noticed he has a 2004 TL mine is up on the 16th of this month i was looking for things to knock out before it expires im not going with the extended warrenty then
Old Sep 8, 2010 | 03:33 PM
TLTrance's Avatar
AVB for President!
A bit off-topic:
Yeah, my f-ing outer door handle fell off and despite being mentioned in a service bulletin, the dealer refused to replace it for me, since the extended warranty does not cover this (trim).
I know I can do it myself, but in order to replace the base of the outer door handle, I have to remove the interior door panel. Yuck.
Old Sep 8, 2010 | 05:38 PM
SouthernBoy's Avatar
Registered Member
Originally Posted by TLTrance
A bit off-topic:
Do you mean the actual door handle or just the little piece of trim at the end that doesn't move with the handle? If this is what you are referring to, you do not need to remove the inner door panel - everything is fixed from the outside and is very simple.
Old Sep 8, 2010 | 06:23 PM
TLTrance's Avatar
AVB for President!
Yes, I mean the little piece of trim (which I think the service manual calls "outer door handle" -- confusing, right?).
The problem is that the old base is defective in the sense that it does not hold the revised trim properly. Thus the base needs to be removed too. I looked at it yesterday and noticed that the base is screwed in from the *inside*... Am I mistakened?
Old Sep 11, 2010 | 08:33 PM
scmrow's Avatar
3rd Gear
Knowledge is power!
Do you have a working link for the steering wheel bulb replacement? The oft-quoted hondacuraworld.com is dead & I would like complete directions/graphics on how to do this. Thanks!
Old Sep 11, 2010 | 08:35 PM
scmrow's Avatar
3rd Gear
What did they quote you on replacing these bulbs? I am not wearing a heart monitor, so fire away!
Old Sep 11, 2010 | 11:40 PM
TLTrance's Avatar
AVB for President!
I just discovered that my passenger side temperature switch bulbs are out. F*ck me! This is now in addition to the resume/accelerate and cancel/decelerate cruise control buttons.
Anyone have an idea of how easy/hard it is to replace the bulbs behind the passenger side temperature switches?
Old Sep 12, 2010 | 07:24 AM
dwb993's Avatar
Guys, bookmark this link. It is also a sticky at the top of every section:
https://acurazine.com/forums/3g-tl-problems-fixes-114/check-these-sources-out-if-youre-having-problem-just-want-learn-something-767930/
Section G of the 3G Garage is where you want to start.
Old Sep 12, 2010 | 03:29 PM
DuoDSG's Avatar
Make it so
Thumbs up
I'm surprised no one has mentioned this yet, but...
2004 TL's do not have the steering wheel buttons backlit. That is something that was added for the 2005 model.
I would know, I have one and I wondered why they weren't lit...so I looked it up.
You'll also notice that a lot of the AC controls aren't lit either, on the right side of where the navi screen would be (circulate air, defroster, etc). Why this was overlooked, even if it was the first year of the new model, is beyond me. Slightly annoying.
Follow the DIY's posted if you want to add your own.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
Charlespsu
Sep 2, 2015 09:54 AM
