Code 0174
Old Dec 3, 2014 | 08:36 AM
JackY Sama's Avatar
Code 0174
Ok guy so I just got this mail on my 2008 tls auto at 70kmileage
The engine came on but went away the next morning I started it the code was p0174 I got it right after I install my led DRL
And I notice my mpg has dropped to a 11-3rate usually it is like 15-17
Old Dec 3, 2014 | 09:05 AM
bauermd's Avatar
System too lean (Bank 2) - I do not believe this has anything to do with your recent install of led DRL.
Sounds to me like maybe a vacuum leak or maybe even a O2 sensor. Might have hit something while installing.
Old Dec 3, 2014 | 09:10 AM
JackY Sama's Avatar
Nope no leak and CEL never came back on the next day I started it been 2week seen then
But mpg dropped
Old Dec 3, 2014 | 09:27 AM
bauermd's Avatar
It still sounds like a lazy O2 sensor that is about to/already has died.
I had P0174 and my code came on and off throughout the weeks. I ended up buying a new downstream Bank2 sensor and replaced it. Code hasn't came back since.
If it were a minor vacuum leak, I don't think your gas mileage would suffer as much as you are describing. If the vacuum leak was bad enough TO cause bad gas mileage, I think you would also be throwing a P0171.
Old Dec 3, 2014 | 09:35 AM
JackY Sama's Avatar
Sould I do a all data run and see if they work when cold/hot
Old Dec 3, 2014 | 10:53 AM
polobunny's Avatar
Registered Bunny
Here's the service manual scan for P0174, if you need it.
Old Dec 3, 2014 | 06:35 PM
240sx acura tech's Avatar
acura master tech
adjust the valves first then replace the injectors if that doesn't work but valve adjustment has fixed it 99% of the time.
Old Dec 4, 2014 | 09:14 AM
515kbpUA7's Avatar
08 CBP TL-S
is it cold out? my 08 type s does this at least once a month. but its cold out and my car idles every mornign to warm up. only does it in the winter months. i just clear the codes and continue on with my day. mpg is probably a coincidence. ive never noticed a change with that code.
Old Dec 5, 2014 | 07:50 AM
acura master tech
needs a valve adjusment
Old Dec 5, 2014 | 09:03 AM
515kbpUA7's Avatar
08 CBP TL-S
been done... even did it a second time to double check.. still does it.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
