Clutch vibration
All motor
Clutch vibration
I just noticed this within the past 2 days. As I ease on the gas and come off the clutch, when the clutch is about 75% out it vibrates slightly. It's not violent, just enough to notice. I don't know what this is or why it's doing it. I do occasionally shift hard, but not very often. I suppose I have been doing it more often this past month, but still nothing too crazy. I have 59K. Anyone?
Also, is this anything the SC check valve mod can fix? Or make better? I assume it has nothing at all to do with it, but it's worth a shot.
All motor
Vibration/Chatter....whatever you wanna call it. I know aftermarket clutches do this, but stock shouldn't...
Registered Member
If your clutch does this when cold, and particularly on cool damp days when you first start out, it's not all together abnormal. I've seen this in other Honda products. If this is how it occurs, it should go away soon after taking off. However, if it happens all the time, it is most definitely not normal. Do you do anything which would fall under the heading of riding the clutch (holding car on hill with clutch, overreving when releasing or shifting into other gears, downshifting without rev-matching or double clutching)?
All motor
I've mis-shifted a few times, but who hasn't? When I was pulling in my driveway today it did it again and I have a wall on either side so everything is louder. I heard it chatter when I released it getting out of 1st gear. The weather is humid and most certainly not cold.
I have (less than a handful of times) just not paid attention and had the car bog to 25mph in 6th gear
without pressing the clutch down. But that was last year, and everything has worked perfectly since. This is a very recent problem.
Thanks for the response.
![No](https://acurazine.com/forums/images/smilies/no.gif)
Registered Member
A miss-shift is not going to have anything to do with the clutch since the two components have nothing to do with one another. And yes, I'm sure we have all had that happen before - I know I have. And bogging the engine is not going to have any effect on the clutch either.
Could you give a more detailed explanation of what you are experiencing, please? So far, what you have described sounds like clutch chatter to me which would be felt as a mild to somewhat strong vibration as you are engaging the clutch.
All motor
How often does this happen? You said, "I heard it chatter when I released it getting out of 1st gear". Do you mean releasing the clutch after moving the shifter from first to neutral (you were on your driveway), or were you shifting into another gear (hard to imagine if you were pulling into your driveway I would think)?
Registered Member
As I mentioned, I have encountered this with other Honda products. One of the reasons for this with our TL's is the fact that the clutch friction disk has a solid hub. In other words, there are no torque dissipation springs which also reduce/elimination chatter. To compensate for this, our flywheel is a dual-mass unit. This unit is heavier and separated from the disk. I suspect the chattering is coming from the dual-mass flywheel contact area when relatively light pressure is exerted by the pressure plate and the other conditions I mentioned, exist.
All motor
Yes, I meant "starting from a stop." Thank you!! ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Sounds like it just is something that happens occasionally. I won't worry anymore, I appreciate it.
Under construction
Sonnick, is it a "creaking" sound..sorry don't know how to explain it? I had a similar noice from my clutch pedal everything I start off in 1st gear. I always thought the pedal/the metal part behind the pedal needed to be greased, idk if that would solve your problem? Mine just went away after a while..weird.
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
