Clutch Slave cylinder removal
Hi guys im having a problem removing the clutch slave cylinder to do the valve removal. I held down the 17 mm nut while trying to loosen the clutch line with the 10 mm nut. I was going counterclockwise but it wouldn't budge and it kinda stripped a little, but i can still get a grip on it with the wrench so its not so bad. Please if you guys have any advice to remove it i would greatly appreciate it thank you!
SidhuSaaB
May 30, 2020 12:40 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
