Need Help ASAP!!!
Old Jun 19, 2014 | 09:59 PM
jmonee4's Avatar
8th Gear
Need Help ASAP!!!
I've read many threads where others were having similar issue:
I have a '06 TL
The Issue: When I turn the key to start the car I will only get a click.
What I've tried so far: First I replaced the battery. It would still only click. Replaced starter, and still only click. Took the new starter back to auto parts store and had it tested. It test as good. Had them test my original starter and it also test good. Next I replaced both battery cables. The connections to the terminals are good and tight. Still get the click.
I found if i turn the key off and on a few times, the car would start.
Anyone have any ideas on what i need to check????
Old Jun 19, 2014 | 11:14 PM
Jackass's Avatar
Does everything else go dead when it clicks? Or do the headlights and such stay fully lit?
Old Jun 20, 2014 | 09:35 AM
jmonee4's Avatar
8th Gear
Everything stays on..
Old Jun 20, 2014 | 11:06 AM
Will Y.'s Avatar
Registered but harmless
Bad ignition switch?
Only a few AZ members have had that occur, IIRC, so it's pretty rare.
Old Jun 20, 2014 | 12:19 PM
jpm3071's Avatar
Try the alternator. Its usually the battery, starter or alternator. If you have a brand new battery, but the alternator isn't working, theres not enough juice in the battery to power the starter.
Old Jun 20, 2014 | 12:59 PM
jmonee4's Avatar
8th Gear
I was thinking it might be the ignition switch, but I think i only found one post about it.
If it was the alternator, wouldn't my battery die after a while? I replaced the battery 3 weeks ago.
Old Jun 20, 2014 | 01:12 PM
YeuEmMaiMai's Avatar
does the little green key flash when you turn the car on?
Old Jun 20, 2014 | 01:21 PM
jmonee4's Avatar
8th Gear
yes it does
Old Jun 20, 2014 | 04:05 PM
jpm3071's Avatar
It will eventually if it is the alternator
Old Jun 20, 2014 | 04:28 PM
robowarrio's Avatar
Tycoon
can't be the battery.... if it was, nothing would turn on in the car, meaning lights or gauges. Has to be your starter or alternator, how bout your fuel pump???? I"m just throwing other components..
Old Jul 8, 2014 | 01:23 PM
jmonee4's Avatar
8th Gear
so broke down and bought another starter again. changed it out this past friday and have not had any issues since. Go figure...
Old Jul 8, 2014 | 01:35 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Guess the first replacement starter was bad Glad you got it figured out.
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
