Clutch Pedal making noise or engine making clunk/motor mount issues?
Old 06-07-2011, 01:56 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Check the 3G TL garage's TSB section for the 2011 updates which has a TSB for both issues!
Old 06-07-2011, 04:30 PM
Registered Member
SouthernBoy's Avatar
Not authorized to view the content....
Old 06-07-2011, 05:37 PM
csmeance's Avatar
you need to follow the instructions at the top of the thread!
Old 06-08-2011, 12:23 PM
04Tl
Yonkers914's Avatar
how does this work, do i call up my local dealer? becuase i have this annoying clutch pedal noise/click for the longest.
Old 06-08-2011, 02:34 PM
the overexplainer
ez12a's Avatar
Same here with the clutch pedal. TSBs eligible for goodwill service? They do mention the 04 model years in a 2011 TSB..
Old 06-08-2011, 03:41 PM
csmeance's Avatar
If you go to your regular dealer where you go for servicing and such, more than likely they will do it under good-will. However, if you go to a dealer for the first time and demand they fix it then they probably wont.
Old 06-08-2011, 05:25 PM
the overexplainer
ez12a's Avatar
shoot. My first Acura was 18 years old and didnt bother taking it to a dealer to fix..
oh well :\ MMMV..
I guess I could take it in for a B(2) inspection..I already did the oil change and filter changes for it (the "2").
02-25-2020 09:57 AM
iCrap
09-11-2015 06:21 PM
Mike Bertram
09-10-2015 09:27 AM
kixo
09-05-2015 08:54 PM
Quick Reply: Clutch Pedal making noise or engine making clunk/motor mount issues?
