Clutch Pedal making noise or engine making clunk/motor mount issues?
Check the 3G TL garage's TSB section for the 2011 updates which has a TSB for both issues!
If you go to your regular dealer where you go for servicing and such, more than likely they will do it under good-will. However, if you go to a dealer for the first time and demand they fix it then they probably wont.
the overexplainer
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
oh well :\ MMMV..
I guess I could take it in for a B(2) inspection..I already did the oil change and filter changes for it (the "2").
rockyboy
01-25-2016 06:00 PM
Mike Bertram
09-10-2015 09:27 AM
kixo
09-05-2015 08:54 PM
