Cloudy Dashboard even after Aerospace 303
My dash was fine before I tried to clean it. Is there a certain way to apply the Aerospace 303 protectant? My dash is getting cloudy after the application.. any help will be much appreciated.
Registered but harmless
Received 1,149 Likes
Did you clean the dash with Honda/Acura vinyl cleaner or a Woolite solution first, before applying the 303?
The 303 Aerospace is a protectant, not a cleaner; the ashy dash is a result of residue "outgassing" and should be cleaned before use of a protectant.
Also, the 303 Aerospace should not be applied to the dash directly-- put it onto a towel or applicator pad for wiping down the dash.
G/L!
G/L!
Take a damp cloth and wipe-down the dash.
Dry with towel, repeat 3x.
Then take a solution of Woolite, 6 parts water, 1 part woolite. Spray onto towel and wipe the surface down. Repeat twice.
Then wipe down the dash again with a damp cloth 2-3 times and then dry.
This will clean up the dash and remove a bit of the stuff that makes it look cloudy. 303 will protect the dash from UV rays and what-not and give it back it's dark color.
Spray 303 onto a MF Towel.
Then wipe the dash down with the MF Towel.
Let sit for a few minutes, then wipe off excess 303 on dash with a dry MF Towel.
NEVER apply 303 directly to a surface, always spray on a towel first.
