Climate Control Issue - temp difference between dirver and passenger vents
Old May 31, 2011 | 04:58 PM
aahuja82's Avatar
Hi All,
My 2004 TL with only 50K miles is blowing not so cold air from passenger side vents while driver side vents blow icy cold. It is not in dual mode and I have tried manual modes and all other settings but the temp difference between two sides is very obvious.
I had service adviser at dealership look at it and he agreed there is something wrong with it but could not have diagnosed until saturday as they were all booked.
Any ideas on what the problem could be before I hand out $$$s to dealership.
Old Jun 2, 2011 | 09:24 AM
aahuja82's Avatar
Any one else having this similar problem?
Old Jun 2, 2011 | 10:11 AM
invalidalias's Avatar
try having someone man the controls in dual mode. remove the cover under the glove box and watch the motor that controls the air outlet flap. As you mess with it you should be able to watch it in action
Old Jun 2, 2011 | 10:57 AM
95oRANGEcRUSH's Avatar
KBPftmfw
Don't the TLs w/ nav have a sun sensing feature that based on your GPS location will adjust the climate on whatever side of the car the sun is hitting?
OP, do you have nav?
Old Jun 4, 2011 | 06:11 PM
aahuja82's Avatar
Fixed!
It has navi but would do that in all directions and times.
This didn't look like motor issue because if I set driver side to maximum heat and passenger side to maximum cold then passenger side would throw cold air but if I set both to cold ( in non-dual mode) then only driver side would throw cold air as if there wasn't enough pressure for both sides.
Anyways, I took it to the dealer and they found leaking valves on both lo and hi pressure lines. They first replaced valves and recharged freon but still lines wouldn't hold pressure so they replaced pipes and now it is working perfect
Little surprised though as didn't expect this at only 50k miles.
Old Jun 4, 2011 | 08:22 PM
Bearcat94's Avatar
AZ Community Team
Glad it's fixed.
While it's only 50k miles, it's ~7+ years. Some things get old and break just by the passage of time.
Old Jun 4, 2011 | 10:56 PM
aahuja82's Avatar
I agree. I think I should put more miles on it to match it age so that wouldn't feel bad when more things break
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
PortlandRL
Sep 14, 2015 12:01 PM
sputik
Sep 7, 2015 01:40 PM
