Climate control buttons - no power
Old Jun 24, 2021 | 08:10 AM
Acura TL Builder's Avatar
I was installing the WCU conversion harness wire to allow the CanBus functionality in the dash behind the clock, and when I put it all back together the climate control didn’t work. No power going to it. While in the process of working on it it worked.
I then removed the clock assembly/navi unit/tape deck and put lithium grease on all the connections. Before and during reinstallation I kept checking and it all worked. After complete reinstallation I start the car and no power again.
Any idea what could be going on? It seems to be a loose wire perhaps?
Old Jun 24, 2021 | 10:19 AM
vpasla1's Avatar
I'm going to go with the generic question of was your battery was connected during this?
and if it was, then check your fuses. Hopefully someone can help out further.
Old Jun 24, 2021 | 01:50 PM
Yes it was the second time, but the climate control power went out the first time with the battery disconnected. I checked the interior and exterior fuse box legends and could now find a “Climate control” or “heater” option, not anything that resembled it.
Old Jun 24, 2021 | 09:34 PM
There indeed is a lose wire that is powering the climate control. If I "bap" either side of the button columns, it works. If it Bap it again, it turns off. Going home today it would turn on an off on medium sharp bump. More sensetive on teh right column of buttons it seems.
I thought it was because I was installing the canbus wire for the ECU conversion that made it sensetive. This area is on tol of the navi behind the clock. but bapping that area produced no results.
PoomPoom
1G TSX Problems & Fixes
19
Oct 18, 2025 05:37 PM
TL3.2000
Sep 23, 2010 11:54 AM
tlmadness
1G TL Problems & Fixes
Aug 18, 2007 08:57 PM
shaglund
Oct 19, 2004 11:23 PM
