Clicking sound under hard acceleration
Old Sep 7, 2013 | 10:06 AM
Modassir's Avatar
I just installed a short ram cold air intake on my 05 TL and during heavy acceleration or suddenly stepping on the throttle you can hear a clicking sound. I was just wondering if this was a problem or not. I've had one of my friends look at it and he said it's the valve behind the cold air intake opening to let air in and the sound is always there, just usually muffled because of the whole air box. I can post pictures of the intake in a few. The intake is just a autozone pipe and filter that I got for free with maybe 100 miles on it the brand is "Spectre" on the filter.
Old Sep 7, 2013 | 11:27 AM
I hate cars's Avatar
Is it a short ram or a cold air intake?
The clicking is not normal. Sounds like a CV joint. Does it happen with less throttle when you're turning? Our engines make plenty of noises from various solenoids including fuel injectors and some have noisy valvetrains but if you can hear it inside the car it's not normal. The throttle valve can have a hiss or whistle but not a clicking sound. Is this a 6mt? Are you running premium fuel?
Old Sep 7, 2013 | 12:12 PM
Modassir's Avatar
It never happens with less throttle, only when I really hit the gas. The car is 6mt running premium fuel. It may be the throttle valve but it sounds almost like a sucking sound like a valve opening up.
Old Sep 7, 2013 | 12:20 PM
A sucking sound is normal. The only way to control engine output is by restricting airflow to it so that's that the throttle valve does. It should follow your gas pedal movement smoothly, no clicking or back and forth. The farther open it gets, the more induction noise you will hear except for the low throttle whistle some cars produce.
Old Sep 7, 2013 | 04:49 PM
Modassir's Avatar
Awesome, thanks a lot. It wasn't bothering me I was only worried that it may be a real problem and none of us were knowledgeable enough to figure it out.
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
mnodaddy
5G TLX Problems & Fixes
Sep 20, 2015 12:14 AM
Iain MacLeod
Sep 17, 2015 01:01 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
sputik
Sep 7, 2015 01:40 PM
