Clicking from rear suspension..
Old Sep 11, 2005 | 12:01 PM
Tom Champagne's Avatar
My 04WDP has had this annoying clicking sound for quite a while now, when ever I go over any bumps in the road,sounds like 2 pieces of metal rattling together. Anyone else have(heard)of this little quirk? It's really noticeable when the you go over a bridge,because of the sound is reflected back at the car from the concrete or whatever solid object the bridge(barrier)is made of. I thought maybe the calipers and brake pads..any help is greatly appreciated.
Old Sep 11, 2005 | 12:07 PM
A_UFO's Avatar
Making sure to eliminate the obvious, have you checked the spare tire compartment to make sure the spare tire and all the tools are secure and you are not hearing them rattle when going of bumps?
Old Sep 11, 2005 | 12:17 PM
jhan1102's Avatar
I had my rear right struts replaced but still makes that noise. =(
They don't know where its coming from.
Demo car doesn't make that noise. >
Old Sep 11, 2005 | 12:26 PM
rear suspension noise
I'm sure the sound is coming from outside the car..not within..plus it seems to be on the right side only.
Old Sep 20, 2005 | 06:13 AM
Abbass Hassani's Avatar
i had that problem they changed my passenger side rear shock and the problem was gone...it is a constant clicking noise coming from teh back...I thought it was from inside the car but i could not locate it...
Old Sep 20, 2005 | 09:55 AM
BillyBeru's Avatar
I figured out where this is coming from on my car. I opened the rear doors and and wiggled (with some pressure) the silver door latch hook that is mounted on the rear quarter panel. When I wiggle mine it makes that "clicking" or "clanking" sound. Both sides make this sound when I wiggle it, but only one side makes the sound when I go over bumps. Now I noticed that the latch tension on each of the rear doors is different. The one that makes the sound while driving has more tension on it. Sure enough, if the door on that side is "wiggled" up and down, the door causes the latch to create the sound. I'm going to try and adjust the door latch to see if that works.
mada51589
Jan 9, 2025 04:40 PM
mazen222
Oct 27, 2015 12:01 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
mnodaddy
5G TLX Problems & Fixes
Sep 20, 2015 12:14 AM
sputik
Sep 7, 2015 01:40 PM
