Chirping noise from the engine bay??
Old Jan 5, 2012 | 03:02 AM
DC2many's Avatar
View My Video
can anyone diagnose? very annoying sound...
thanks
Old Jan 5, 2012 | 06:32 AM
Turbonut's Avatar
Expected to hear a much clearer sound, but if you can't pinpoint the precise location and as long as the sound is coming from the left side, remove the serpentine belt and start the car for a short period to see if the noise is audible, and if no noise check the belt and pulleys.
Old Jan 5, 2012 | 10:20 AM
MOTU's Avatar
4th Gear
There is a service bulletin regarding "timing belt chirping" on 05 - 08s
Old Jan 5, 2012 | 01:44 PM
DC2many's Avatar
i will look into the service bulletin
edit: i cannot look at the service bulletin
TSB 08-031: Chirp From the Timing Belt Area
Old Jan 7, 2012 | 09:26 PM
allin's Avatar
There are 2 possibilities - one is the aforementioned timing belt idler pulley, the other is the a/c pulley mounting bracket. There is a TSB for that one as well.
I had the a/c pulley mounting bracket (07 TL). It was a chirping noise at cold start situations - noticeable mostly at idle. The dealer had to use longer bolts and modified mounting bracket. Noise went away after dealer fix.
Old Jan 7, 2012 | 10:47 PM
allin's Avatar
By the way, your video sounds exactly what my car sounded like. I don't know what the timing belt issue sounds like.
Old Jan 7, 2012 | 11:43 PM
DC2many's Avatar
Do I just ask about "TSB" fixes when I walk into Acura? I'll stop by the nearest Acura tomorrow or monday
i thought that pinging/chirping noise was my knock sensor at first since i had a CEL for it that kept reemerging. so after fixing that the noise was still present, thus the video.
Old Jan 8, 2012 | 05:46 AM
Turbonut's Avatar
Kind of difficult to ask about a specific TSB when you're not even sure of the origin. If you're going to take it to Acura, just walk in, tell them you have a noise and description, throw them the keys and walk away. Wait for their findings and go from there. If you're not sure of the cause, bad idea to tell service what you think the problem might be.
Old Jan 8, 2012 | 07:06 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^this. it was hard to tell where the chirp is coming from in your video.
if its the passenger side then it might be the timing belt. if its else where then its probably another belt, tensioner or pulley.
when does this chirp occur? the more spcific you are about the noise and when it occurs, will help the dealer find it easier.
good luck.
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
