Check Engine Light/Rattling Noise
Old Dec 1, 2013 | 04:00 PM
CenturionTL's Avatar
I have an 2004 TL.
I hit a minor pothole 2 weeks ago and my check engine light about 30 minute afterwards.
I ran the code and it stated the following:
ABS Sensor malfunction
Steering Sensor malfunction
Low battery voltage
I cleared the code but the check engine light came back on the next day.
Two days the check engine light just turned off by itself
Then yesterday the check engine light turned on again yesterday and I am starting to hear a rattling noise when I accelerate.
The rattling noise appears to come from the front engine perhaps on the passenger side area, I cannot ascertain the exact location.
Old Dec 1, 2013 | 04:49 PM
3.2TLc's Avatar
Welcome CenturionTL !!!
Nearly 10 year old cars hitting potholes and CEL's are rather common.
ABS sensor, Steering sensor malfunction, & low battery voltage codes, hmmm ?
~ Cleared, but back, 2 days later off, then today CEL on & rattling on front side.
It appears as though the pothole may have disrupted your car's sensors and possibly something requiring closer inspection up front.
Old Dec 1, 2013 | 07:47 PM
Its only rattling when I accelerate
Old Dec 2, 2013 | 07:39 AM
I hate cars's Avatar
I was going to say wheel speed sensor on the wheel that hit the pothole until you said it has the rattling sound on acceleration. The only thing I know of that would link those codes together plus a rattling (if it's preignition) is a bad power or ground wire, probably ground. I would start at the battery checking those connections and checking voltage with the engine running.
Just to clarify, the rattling noise is only there under acceleration and never when coasting or idling, right?
Old Dec 2, 2013 | 09:41 PM
Yes rattling noise is only under acceleration of 1-2 rpms.
Old Dec 4, 2013 | 07:04 PM
check engine light has turned off again.
I think it might be a sensor malfunction.
But I still hear a rattling noise when I accelerate between 1-2 rpms.
Old Dec 5, 2013 | 12:47 AM
it appears to be coming from the driver side engine or wheel area.
Old Dec 9, 2013 | 09:13 PM
check engine lights turns on for 1 day, then the next day it turns off.
Old Dec 12, 2013 | 05:21 PM
check engine light off for 3 days now it is on.
Old Jan 31, 2014 | 10:09 PM
Still same thing. Check engine lights comes on and off. It stays off for weeks at a time then comes on for few hours and goes off.
I'm guessing its a faulty sensor? Or a wire is not grounded?
I took it to an Acura Dealership the other day told them the codes, and the tech said everything was fine. The CEL light was not on at that time.
Old Jan 31, 2014 | 11:27 PM
ArAbiAnArAb's Avatar
this has been happening to me since I had my car (2 years) and it is a 2008 TL...I've read stories of ppl fixing the problem by changing the O2 sensors and others have had to replace their cats...i havent went about fixing the O2 sensors but I think I may try that real soon once this tax money comes in LOL
Old Feb 1, 2014 | 05:53 AM
YeuEmMaiMai's Avatar
check for a loose heat shield on your cat. they love to rattle when the welds finally break. The dealer *SHOULD* install a metal band around the cat free of charge...
it is common for the VSA light to come on when you hit a big enough bump or pothole.
to be sure it is the issue pull the codes stored in the system.
Billu99tl
Sep 13, 2015 11:30 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
