Check Engine light came on????
Old Jan 6, 2013 | 08:23 PM
bluetl04's Avatar
So my 04 TL has not been driven within the last two weeks. Today I went to start it to let it run a little and the check engine light came on. Could this be cause the car was sitting and it has been cold here in ct? The check engine light wasn't on before. Anyone that can shed some light on this will greatly be appreciated. Also I can't move the car to take it to auto zone because I have the front bumper off.
Old Jan 6, 2013 | 08:36 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
my car has sat for up to two weeks a few times...no problems here.
O2 sensor may be going bad if the car seems to run fine. our 03 accord threw a CEL earlier this yr...car ran fine...checked the code and it was a bad O2 sensor. had it replaced no problems since. this car is DD.
Old Jan 6, 2013 | 08:46 PM
HEAVY_RL's Avatar
you can guess at it all day, pulling the code is the only way to know.
Old Jan 6, 2013 | 08:49 PM
bluetl04's Avatar
All 4 o2 sensors are new
Old Jan 6, 2013 | 08:50 PM
bluetl04's Avatar
Yeah I def agree with you
Old Jan 6, 2013 | 08:52 PM
HEAVY_RL's Avatar
I had a car throw a knock sensor code after sitting for a while in the cold, I reset it at the battery and it never came back.
Old Jan 6, 2013 | 09:19 PM
bluetl04's Avatar
I'll look into that. Thank you
Old Jan 6, 2013 | 09:31 PM
nfnsquared's Avatar
So that makes me ask why? What other changes/mods have you made to the engine/exhaust/intake ?
And FYI, for $30, you can check the codes yourself:
http://www.newegg.com/Product/Produc...9SIA0XA0851767
They are on sale at times for only $20.
Old Jan 6, 2013 | 09:57 PM
bluetl04's Avatar
Well the two top 02 sensors went bad and I changed them. Later on I just went ahead and changed the two lower ones just cause I wanted to. I have a aem cold air, rv6 v3 pcd's, rv6 v3 j-pipe and comptech cat back
Old Jan 6, 2013 | 10:12 PM
nfnsquared's Avatar
Yeah, no telling with the PCDs. You'll have to grab the code.
Old Jan 7, 2013 | 09:10 AM
ZOMGVTEK's Avatar
No reason to even make a thread saying you have a CEL if you don't know the code. Pull the code. Thats going to help narrow down the problem from damn near anything, to a few specific problems.
I don't know specific laws for your state, but can't you drive anywhere you want without a bumper cover? Unless of course, you physically unbolted the bumper itself, which is the big metal bit.
Old Jan 7, 2013 | 09:22 AM
HEAVY_RL's Avatar
The only problem driving without the bumper cover is that you have to tie up all of the splash guards and hope nothing hits the radiator.
Old Jan 7, 2013 | 09:26 AM
HELP! I threw a code. I know what I need to do to read the code...but HALP!!!!
Old Jan 7, 2013 | 09:31 AM
HEAVY_RL's Avatar
calm down sir, have you tried a relay?
Old Jan 7, 2013 | 09:34 AM
BUTT, PLEASE HALP!
MY car threw a code.
Old Jan 7, 2013 | 09:39 AM
HEAVY_RL's Avatar
whoa whoa... do you see any relays.
Old Jan 7, 2013 | 10:40 AM
nfnsquared's Avatar
Justn, have you called PayPal? If not, get on it!!!
OP, the rest of us (OK, maybe Justn too ) are here to help once you get the code read
Old Jan 7, 2013 | 10:47 AM
HEAVY_RL's Avatar
so there is no relay? hahaha... Paypal never gets old
Old Jan 7, 2013 | 10:50 AM
one last time...
HAAALP!
Old Jan 7, 2013 | 11:42 AM
UA6's Avatar
UA6
Old Jan 7, 2013 | 11:43 AM
Mrtastygoody's Avatar
Level: Noob
Just threw one the other day too, but it's an 02 sensor for me. Not to derail, but I don't really understand which sensor is which. Where is Bank 1 Sensor 2 located? I searched and found stuff, but didn't quite get it from the threads I found.
Old Jan 7, 2013 | 01:29 PM
nfnsquared's Avatar
Bank 1 corresponds to the bank with cylinder #1: The rear bank. Sensor 2 is the downstream sensor (or the sensor at the bottom of the precat).
Old Jan 7, 2013 | 02:24 PM
Level: Noob
How hard is the sensor to get to? Luckily, that's one of the cheap sensors. Unluckily, nobody has it in stock.
Old Jan 7, 2013 | 08:43 PM
bluetl04's Avatar
I understand that without a code it s hard to tell what it is. I just wanted to see if anyone ever went through not starting the car for a while and when they did, the check engine light came on, only cause my car is not drivable at the moment. But thank you
bluetl04's Avatar
Exactly, thank you very much
Old Jan 7, 2013 | 08:48 PM
bluetl04's Avatar
Thank you bro. I will get it read as soon as I get my bumper back on. And if anyone was wondering why I haven't driven it, it is because I just bought a winter/work car that I am using now. It's a 95 Infiniti g20t , 96k original miles, one owner..
Old Jan 8, 2013 | 07:06 AM
i'm only giving you shit because; its so broad.
"hay guise! I set down a pie for a week and now its gone!
Can anyone tell me what happened to it?"
there's about a million answers.
but only one right answer.
which is to call paypal
Old Jan 8, 2013 | 07:50 AM
HEAVY_RL's Avatar
yup, always paypal... always.
Old Jan 8, 2013 | 12:11 PM
blkmz3's Avatar
all these replies trying to guess what it is and no code read. wow. just borrow the scanner from autozone or a friend or buy the cheapo $20 one.
Old Jan 8, 2013 | 04:53 PM
bluetl04's Avatar
I'm not guessing about anything. If I could have it scanned, then I would have not started this thread. But like I said, my car is not moveable. Autozone does not let you borrow scanners here. I don't have to buy one cause I'm not in a rush to find out the code because once I get my headlights back, everything will be back on and then I can go get it scanned.
Old Jan 10, 2013 | 12:51 PM
blkmz3's Avatar
might as well diagnose the CEL while the car is out of commission. i'm sure you can find someone with a scanner. by the way all Autozones do loan-a-tool. check advance auto.you have to put down the full deposit though like if you're buying it. once you get the code i'll be more than happy to help. put some fresh gas in it and drive the car too.
Old Jan 20, 2013 | 05:31 PM
bluetl04's Avatar
Okay, so I got my headlights back and put everything back together. I took the car for a ride and the check engine light went away. So I'm guessing it came on from the car sitting for a while. But thank you all for help.
Old Jan 20, 2013 | 07:46 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^doesn't mean the code isn't being stored by the car.
Old Jan 20, 2013 | 07:59 PM
supraru's Avatar
I can't believe I just read through this thread out of boredom. It's amazing how little people understand cars. "I think my cel just came on because it sat for two weeks." Rofl....dude you can't be serious can you?
Old Jan 20, 2013 | 08:14 PM
bluetl04's Avatar
Nobody forced you to read it. You chose to. And yes I am serious
Old Jan 20, 2013 | 08:21 PM
supraru's Avatar
You're right no one made me read it. Think about this logically. Why would a check engine light come on in your car just because it sat for two weeks? You realize why cel's come on in general right? The funny thing is you're so newbish that you refuse to pull the code. Any time a cel comes you you should really want to know what is wrong with the car and why it's on. Sometimes you can clear it and it won't come back but most of the times there is some sort of issue.....hence why it comes on in the first place.
bluetl04's Avatar
And no it's not amazing how little people understand cars. Some have a lot of knowledge about cars and some have very little. Not everyone is the same. That's what this forum is for. To help people understand and solve problems that one may have. So if you wanna be a smart ass, you can kick rocks
Old Jan 20, 2013 | 08:27 PM
supraru's Avatar
Yes that is why the forum is here. Everyone said to go get the cel pulled. You decided in your obvious lack of knowledge to assume since the cel went out the cel light must have been a "car sitting for two weeks or longer" cel. You are lucky you didn't make it to 4 weeks. That one doesn't go out.
I don't get it, if I was being a smart ass why would I want to kick rocks?
Don't be lazy, pull the code and see what your issue is with your car.
Old Feb 9, 2013 | 06:07 PM
bluetl04's Avatar
So I went to auto zone the other day to see what codes come up. And no codes showed up. My cel hasn't come on since. So I'm thinking it had something to do with the pcd's. I could be wrong but if it comes on again, I will get it checked out.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
