check engine light.
Old Aug 18, 2009 | 05:27 AM
thait's Avatar
I need a car in
check engine light.
check engine light.
so i have a 2005 acura tl base w/navi auto. the car has 74k on it. when i turn the car to on the check engine light would stay on then blink 5 times then turn off. is this normal? or is it trying to say something. if i put the key in and turn it to start and let go the light just disappear.
Old Aug 18, 2009 | 07:43 AM
hamsup's Avatar
got boost?
Originally Posted by thait
check engine light.
hmmm..sounds like it could be a "miss fire" code
mine did the same, would tay on, then start flashing. and it turned out being a cylinder 4 miss fire..get it checked out. i heard many guys here are having the same miss fire codes
Old Aug 18, 2009 | 10:09 AM
Majofo's Avatar
I wouldn't worry about it unless it stays on or comes up while you're driving. It's probably just system diagnostics.
edit: also make sure your gas cap is closed all the way (3 clicks).
Old Aug 20, 2009 | 03:22 PM
thait's Avatar
I need a car in
ill try the gas cap thing. anything else i should check?
Old Aug 20, 2009 | 04:29 PM
liquiditys's Avatar
I'm also currently having engine misfire codes but my light stays on. If your's turns off, I would go to the nearest shop and usually they would hook up the obd reading thing (not sure what its exactly called) and it'll tell you whats wrong.
if it's p0300 it's a random misfire, if it's p0301-0306 the last number indicates which cylinder is misfiring. I'm currently trying to fix this shit myself so someone please correct me if I'm wrong!
Old Aug 20, 2009 | 06:54 PM
ABP_04TL's Avatar
6-SPEED LOVER
i got the same issue, get a BIG tune up done...
dats wat im gettin done maybe this weekend
Old Aug 24, 2009 | 01:36 AM
thait's Avatar
I need a car in
what is a BIG tune up ?
Old Aug 26, 2009 | 02:39 PM
hamsup's Avatar
got boost?
new motor..lol
Old Aug 26, 2009 | 02:49 PM
andrew070489's Avatar
plugs, seafoam, oil change, fluids
Old Aug 26, 2009 | 02:51 PM
Majofo's Avatar
I like the new motor suggestion better..
Old Aug 26, 2009 | 03:46 PM
thait's Avatar
I need a car in
lol, im fine with a new motor. car has extended warranty so if the dealer would give me a new motor ill be a happy cherry =]
Old Sep 4, 2009 | 03:08 PM
alexSU's Avatar
Under construction
My check engine light came on yesterday. It gave me the cylinder misfire codes, all 6 The guys at AutoZone reset the computer and check engine light went away, for now.
I just seafomed my car about 2 weeks ago, why did it throw those codes out?? I'll be changing out the spark plugs this weekend and I've changed my oil every 3500 miles.
Old Sep 4, 2009 | 03:21 PM
Majofo's Avatar
you mean you got a misfiring CEL on your saab turbo?
Old Sep 4, 2009 | 03:48 PM
alexSU's Avatar
Under construction
haha you got me
jk
i'm still driving the TL for a few more days. saab is getting delivered this weekend
Yikes
May 3, 2021 04:29 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Billu99tl
Sep 13, 2015 11:30 AM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
