Check engine light for 10 seconds
Old Sep 6, 2012 | 08:41 PM
GeeteeDan's Avatar
I Like turtles
On the way home after pulling off the highway i got on it just a little. The check engine light started flashing and after 10 seconds went back off. This is the first time ive seen the light since ive had it and doubt any codes will be there since it went back off. Any clue
Old Sep 6, 2012 | 09:20 PM
Slpr04UA6's Avatar
-------Tim-------
Random misfire. Have you had the ECU reflashed? There is a TSB for us '04's (random misfire) I had the local dealer perform the reflash. This was after 3 visits with just the random misfire codes, nothing done by them initially till I found the TSB and asked for it to be done. Haven't had the problem since. It cost ~$50.
Old Sep 6, 2012 | 09:30 PM
GeeteeDan's Avatar
I Like turtles
Haven't had anything done to the ecu but I'll check it out.
Old Sep 6, 2012 | 09:58 PM
Slpr04UA6's Avatar
-------Tim-------
^just to clarify.....they (dealer) will reprogram the ECM/PCM (ECU) according to the TSB. Sorry I don't have the TSB #..
Old Sep 6, 2012 | 10:16 PM
nfnsquared's Avatar
And if it's due to the TSB, it's harmless. The ECU is misinterpreting signals and actuating the MIL. There is no actual misfire. But I'd still get it flashed.
Old Sep 7, 2012 | 06:09 PM
roof2006's Avatar
Thanks for the heads-up. I've been ignoring this issue for 120,000 miles now. - it only happens to me after I put the pedal on the floor after exiting a long high-speed turn. (like freeway cloverleafs.) I had thought it was oil sloshing around - glad to hear it's nothing.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
