Changing pads on TL S type
Old Oct 25, 2009 | 10:42 AM
mlvii's Avatar
Question Changing pads on TL S type
Novice to changing pads on the TL S. Noticed that when seperating calipers, fluid leaked. How do I take of the calipers and contain the brake fluid. Appears to be a shut of screww on both sides, but then I will not be able to move the piston. Need some help.
Old Oct 25, 2009 | 11:07 AM
csmeance's Avatar
those are the bleeding screws if I remember correctly. You need a piston compressor to put the pistons back, you can rent them for free from autozone, 100 dollar deposit.
Old Oct 25, 2009 | 04:24 PM
Turbonut's Avatar
You don't remove the calipers.
Old Oct 26, 2009 | 01:15 AM
Bearcat94's Avatar
AZ Community Team
... and you don't need to open the bleed screws.
Here are the DIY's:
Service Manual Scans:
D-041: Brakes-front/rear caliper overhaul, front/rear pad replacement, brake bleeding, brake disc specifications, parking brake adjustment
https://acurazine.com/forums/showthread.php?t=118283
D-094: DIY:Brembo Brake Pad Replacement + Rear Brake Pad Replacement
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/3g-garage-d-094-brembo-hawk-pad-replacement-w-pics-579140/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/diy-2007-tl-s-brake-pad-replacement-629428/
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-how-replace-brake-pads-acura-tl-s-733637/
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-complete-brake-job-pics-624404/ - Rear Pads as well
Old Oct 26, 2009 | 05:35 AM
Turbonut's Avatar
As he stated he separated the calipers and fluid leaked out, maybe when accessing the pads, he tried to split the caliper, not knowing how simple the replacement might be, and I'm assuming he's speaking of the front pad replacement.
Also, when replacing pads, some undo the bleeder to let the fluid bleed out when the pistons are pushed back into their bores. This makes it much easier, and also allows the addition of new fluid into the master cylinder rather than having the "old" fluid pushed back into the reservoir.
Old Oct 26, 2009 | 05:39 AM
TL black's Avatar
You can probably push the pistons back in with your hands.Just loosen the master cylinder lid.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Aleax
Sep 11, 2015 11:31 AM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
