Center Console Power Socket Won't Work
Old Jul 3, 2011 | 10:09 AM
VieTLover's Avatar
BRB..Shifting!
My front power socket works, but my center console one doesn't work. I already checked my fuse that says Front Accessory Socket and it isn't blown. Any advice?
Old Jul 3, 2011 | 11:52 AM
RonC5's Avatar
Rocket Scientist
Change the fuse anyway. I have looked at them before and thought they were okay, but changed it and solved the problem. Worth a shot for a $1 fuse.
Old Jul 4, 2011 | 12:47 AM
VieTLover's Avatar
BRB..Shifting!
Ok I will give it a try tomorrow thanks!
Old Jul 4, 2011 | 01:22 PM
VieTLover's Avatar
BRB..Shifting!
So I replaced the fuse this morning and same results, the front socket works but the center console one still doesn't. Is there any other thing I can do?
Old Jul 4, 2011 | 02:04 PM
paperboy42190's Avatar
check the wiring underneath the center console. good chance the plug that it connects to came loose.
Old Jul 4, 2011 | 05:34 PM
csmeance's Avatar
Many tech's forget to plug back in that power outlet when they put back the center console together. It's fairly easy to open up and check. Remove the silver strips and the 4 screws and simply slide back an inch or so and then lift up! The DIY to remove the center console is posted in the garage!
Old Jul 5, 2011 | 12:01 AM
VieTLover's Avatar
BRB..Shifting!
thanks guys will do tomorrow.
Old Jul 5, 2011 | 10:28 AM
VieTLover's Avatar
BRB..Shifting!
So I just got back from taking my center console apart and it was really scaring taking them trim pieces off especially in the top part near the controls and stuff but I did manage to take it off. I found out that I didn't even have to take the top part off just the bottom. But anyways, I found out the problem why my center console power socket doesn't work is because the previous owner had a sub/amp and he installed a lil gauge for the battery voltage in one of the cup holders. I knew this prior to buying the car, but it turns out that in order to power up the lil guage he cutted the power socket black and white wires. So, what can i do to make it power back? I don't know much but I always love to tinker around in the car. Thanks for your help guys.
Old Jul 5, 2011 | 08:59 PM
KnightRider3575's Avatar
Not to be a smart ass but reconnect the wires and if you have no need for what the other guy put there then take it out... Its best to use a soldering iron but if not get the crimp on connections and make sure to use something to cover the connection or it might ground out being near to the body of the car.... Take care
Old Jul 6, 2011 | 09:59 AM
VieTLover's Avatar
BRB..Shifting!
But the thing is that I still do want the lil guage to be there. I can't have both?
Old Jul 6, 2011 | 02:30 PM
you can, but you just need to have the wires run in parallel that way both objects see 12v of power. however keep in mind that if the gauge thats too much power, and you combine it with using the power socket, it may overload the fuse and blow it. however that may not even happen, just keep it in mind, and dont put like a 75W plug adapter on the car socket.
Old Jul 7, 2011 | 12:44 PM
deantl's Avatar
This is exactly what happened to my 07TL. I had the socket replaced, now it is fine.
Old Jul 7, 2011 | 08:16 PM
VieTLover's Avatar
BRB..Shifting!
deantl I don't get it, you had the socket replaced and it was fine? But my problem is that I still have the socket just the 2 wires in the back aren't connected to anything. So I guess I just have to crimp my original wires and just connect the wires that are attached to the socket but isn't attached to anything. does that sound right? lol
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
acurajj
Sep 19, 2015 03:47 PM
usdmJON
Sep 4, 2015 12:59 AM
