CEL help. Using the blink method
Old Nov 19, 2014 | 11:33 AM
IIDXholic's Avatar
Hi everyone I have 15 long flashes and 3 short ones. Would that indicate a P1503? I tried finding information on how to find it but found the method to pull the codes with a paperclip on another forum. Thanks!
Old Nov 19, 2014 | 12:17 PM
acrdr's Avatar
try going to your local autozone they scan cel for free
Old Nov 19, 2014 | 12:22 PM
erdoc48's Avatar
06 Anthracite TL
I think everyone should get a CEL scanner for home use...they're really cheap these days (about $25-30) and it is very useful to get codes and clear them if it's a minor issue. Look on Amazon, they're pretty cheap there. Trying to do it with a flash method seems tedious and possible inaccurate.
Old Nov 19, 2014 | 12:56 PM
IIDXholic's Avatar
I do have one, its a Innova 3020, but for some reason its giving me "error" code every time I try to read it which is why I have to resort to the paperclip method.
Edit: I guess I am using the flash method, which is 15 long flashes, and 3 short ones. Indicates P1503 right?
Old Nov 19, 2014 | 12:59 PM
just go to autozone!!
Old Nov 19, 2014 | 01:02 PM
IIDXholic's Avatar
im at work!
Old Nov 19, 2014 | 09:27 PM
paperboy42190's Avatar
I guess some of you guys are still lucky that autozone does it. Here in CA its not allowed anymore.
Old Nov 21, 2014 | 02:10 AM
hisost's Avatar
As erdoc said, everyone should have an obd2 reader. Get an obd2 Bluetooth adapter that connects with windows/android. Mine costed $15 off amazon and another $5 if you wanna pay for the Torque Pro app. It reports everything the ECU has..from sensors to fault codes. You can clear the codes too with it. Also insanely easy to setup, took less than a minute.
Old Nov 21, 2014 | 06:27 AM
lol, why would any one try the blink method?
as stated its confusing and possibly inaccurate
Old Nov 21, 2014 | 03:19 PM
flyromeo3's Avatar
code 15: Ignition Output Signal - Open or Shorted out ignition signal circuit / No Signal to ECU
Code 03: Map sensor circuit - Oxygen sensor or circuit, ECU
possibly a bad o2 sensor.
Old Nov 21, 2014 | 03:21 PM
flyromeo3's Avatar
but yeah, CEL code readers would be a better bet in accurately diagnosing.
Mike Pilipenko
Mar 26, 2024 09:21 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
ripit
Sep 26, 2015 06:19 PM
