CEL Flashes when WOT.. Misfires in Engine?
Old Mar 15, 2009 | 01:31 AM
ILLustriousUA6's Avatar
Feenin on some 20's
The first time this happened was when I was doing a couple of runs at the track. I went WOT(WIde Open Throttle) and start noticing the CEL flashing. SO I let off the throttle and still does this. SO WTF is going on? Well, i did a few more runs and same thing happens. Nothing in the engine was showing any signs of smoke or any bad wear. So on my last run, I just held the throttle down to the floor, even while the CEL light was blinking and after the run, I look down and noticed that the CEL stayed on.
It didn't go away for a day or so and then I was a bit concerned so I took it to the dealer the next day. The guys ran the code and saw that it was the Cylinder Misfiring. And that was all, they took the code off and told me that since it was my first time, they wont charge me, but the next time I come back with the CEL light on, they will charge me to turn it off.
So everything's fine till I stomp the pedal to the floor going on the the highway(merging to the HW) and same light goes on, I leave it there and goes off after 2-3 days...
SO the question is, could it be my spark plugs? This happened at around 30k and now i am at 60k. Weird thing is, it comes on only once in awhile when i floor it. MOST of the time I floor it, this doesn't happen.
ONE MORE THING. The dealer guy blamed it on my INtake... First thing I thought of when he said that was, could it be that my car's a/f ratio is messed up due to the Intake?
TIA guys.
Old Mar 15, 2009 | 01:34 AM
Feenin on some 20's
And o yea, I am still on my first set of spark plugs, that came stock with the car when it had 3 miles on it.
I am at 60,xxx miles now and I am considering on changing my spark plugs soon. Most likely be going with Iridiums, but don't know which kind. If anyone can list which kind I should get, please post up! I am in it for performance, so the best of the best would be perfect, as I do plan on taking it to the track real soon. =)
ib18c1's Avatar
Former Sponsor
hey Donald, have u checked your oil if it's too low or course? I have this same exact code and problem in my rsx when the engine oil was low, so it wasn't lubing the pistons enough...not sure if it's the same but doesn't hurt to check
Old Mar 15, 2009 | 01:36 AM
HONgDA's Avatar
2005 TL (7/07-8/29/09)
Check to see if the weld to the vibra-mount isn't broken on the cai. Other than that I don't know what's wrong.
Old Mar 15, 2009 | 01:41 AM
Feenin on some 20's
TIM: thnx man, i guess i'mma be checking that tomorrow before i change my oil. This doesn't happen much but once in awhile, it just pops up. ugh.
TONY: OK, i'll give that a check as well tomorrow.
Thnx again for your help guys.
Old Mar 15, 2009 | 10:14 AM
PeterUbers's Avatar
I have the same issue -- it's been brought up several times before the forum .. it can happen with in SS mode and going WOT .. comes up once in a while --
Apparently there is a crankshaft sensor TSB that I saw a while ago (> 2 years ago) that somehow resolved this...
I wouldn't hesitate to pull the code, however, just to make sure it isn't something worse.
Old Mar 15, 2009 | 10:42 AM
SpecTro's Avatar
I joined the club yesterday for that Thanks AEM
Anyways, i was not throwing a code with that problem on the car, and did do a couple of WOTs on the freeway and such.
I can tell you that i have gotten that CEL on SS mode, at WOT only and only IF i let the rev limmiter hit and stay there for a few secs, of course, not on purpose, just by mistake when i noticed... 3 times different days but it'll usually go away in like 10 secs or less.
Old Mar 15, 2009 | 07:18 PM
Feenin on some 20's
so the sensor is a bit messed up? How should I go about this problem??
Old Mar 16, 2009 | 11:31 AM
bhelsdon's Avatar
http://www.in.honda.com/Rjanisis/pubs/SB/B03-033.PDF
You should read this if your car is an 04.
Old Mar 16, 2009 | 09:14 PM
JMillerUA6's Avatar
Chapter Leader (New England)
+1
My car was doing the exact same thing. Took it to the dealer for a reflash, and haven't had the problem since.
1 Hour, $52
Old Mar 16, 2009 | 11:09 PM
PeterUbers's Avatar
That's the TSB! wow, you guys are good.
Old Mar 17, 2009 | 01:24 PM
Hi speed's Avatar
runnin a little boost
Stop going WOT. j/k
PS. I don't know how you passed me that night, but it won't happen again
Old Mar 19, 2009 | 08:19 PM
Feenin on some 20's
Originally Posted by Hi speed
Stop going WOT. j/k
I WOT everday. lol.
when did i pass u? and which night was it? Don't tell me it was you that passed by me again after i exited tully/capital. last week? I thought i saw u, but i know what u got under the hood, so it wouldn't be fun anymore.
Old Mar 19, 2009 | 10:10 PM
Hi speed's Avatar
I WOT everday. lol.
It was over a year ago, coming from 680-101 south, I saw your lights and thought bye bye auto. Some how you passed me at hi speed. I was stock but the 6 speed is a monster in high revs so i couldn't believe you were abel to keep up much less pass. I only see grandmothers and asian women driving TL's, so modded ones stickout and I never see any.
Old Mar 20, 2009 | 12:10 PM
ssmtl2nv's Avatar
2009 g37s 6mt
I had the same prob, and my motor went bye bye......
Old Mar 20, 2009 | 03:35 PM
JCL622's Avatar
A-spec steering wheel ftw
mine's been doing this since i stuck on my j pipe and custom exhaust....that was about 1.5 years ago? car still drives after 8000 miles;
haha my only real problem is once the CEL stuck and i pulled the plug and reset it to see if the CEL would pop up again, (CEL never came back up) but now i havent been able to pass inspections for 3 months ...EVAC and CAT still say not ready
Old Mar 21, 2009 | 01:42 AM
Feenin on some 20's
lol, oo, that was a LONG time ago. It was fun. I remember u passed by me AGAIN on Blossom Hill. I heard a whine and i immediately knew it was a s/c TL. The whine's very unique.. I was the white/bronze TL at the light, about to make a left to Juicy Burger..
and o yea. i'm not new to the race scene btw... .. I have intake+exhaust. I was surprised myself, I thoguht u might've misshifted.
PS> I have beaten many cars that i shouldn't have beaten.
Old Mar 21, 2009 | 01:50 AM
Feenin on some 20's
please explain. If my motor goes Byebye soon. is it covered under warranty?
done that before and it goes away, but comes back
Old Mar 22, 2009 | 01:04 AM
hata_61's Avatar
If its not the reflash that you need then A flashing CEL/MIL in the OBD2 world means the computer is trying to tell you a catalyst damaging fault is ocurring. So a misfire would be one of them.
Old Mar 22, 2009 | 11:43 AM
s0leheir's Avatar
wait for me!
I had the same problem in my 04 AT. They fixed it with a reflash update that was released by Honda/Acura.
Old Mar 22, 2009 | 12:57 PM
TylerT's Avatar
Turd Polisher
I have the same problem, more input is appreciated.
Old Mar 23, 2009 | 11:15 AM
bhelsdon's Avatar
I would think this should explain everything.
Old Apr 19, 2009 | 07:39 PM
pascalladal's Avatar
6th Gear
what is the finale ..with te cel flashing ??? i have the same probleme....2 times in 3 weeks at WOT
Yikes
May 3, 2021 04:29 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
ibGTV
Sep 28, 2015 03:40 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
HeloDown
Sep 8, 2015 06:51 PM
