car wont start1!! arghh
Old Jan 11, 2011 | 03:41 PM
SCS15's Avatar
Well I just had major elbow surgery about 3 weeks ago and haven't been able to drive so my 3g was sitting in the street basically the whole time.
Tried the other day to start the car, wouldnt start, everything had power, (dash/nav/headlights all worked)but tried to jump it anyway and didn't help.
Noticed car was on E, so I threw in a gallon of gas today. Started up very rough, ran for about 10 seconds and cut off.
Background: Battery and alternator replaced last winter. Car ran fine about a month ago, started and drove no problem.
Old Jan 11, 2011 | 07:01 PM
nfnsquared's Avatar
Pull your battery connections and clean them, then re-tighten. The battery clamps don't seem fit aftermarket batteries very well.
There have been tons of people with starting problems only to find out it was a loose/dirty/corroded connection. You indeed could also have a weak battery from sitting 3 weeks.
Old Jan 12, 2011 | 02:54 AM
SwaggaDaddy's Avatar
If our battery connections are corroded out how much will it cost to replace? and can I do it myself?
Old Jan 12, 2011 | 08:07 AM
Comptechtl2367's Avatar
All you need to do is clean them, not replace them.
Old Jan 12, 2011 | 08:50 AM
SharksBreath's Avatar
BANNED
^listen to this guy.
i had the same deal as you, SCS15. i disconnected the battery connections, cleaned some corrosion off, applied some terminal protectant, haven't had a problem since.
Old Jan 12, 2011 | 08:55 AM
not if they look like this....
if they get this bad, then you will need to replace. yes you can do it yourself.
Old Jan 12, 2011 | 09:05 AM
nfnsquared's Avatar
^^^Mine weren't that bad, but close. There are commercial corrosion cleaners you can buy, but I did it the old fashioned way: I removed the battery and then dipped each connector in a disposable plastic cup fill with baking soda mixed with warm water and let it soak for 5-10 mintues. Then I used a wire brush dipped in the baking soda solution to knock off the stubborn stuff. You could also probably use an old toothbrush. I also used the brush on the battery terminals and doused the top of the battery with a baking soda/water solution.
As mentioned earlier, I highly recommend buying terminal protectant/pads. You can get the pads and a spray can of the stuff packaged together at Wally World for under $5. If you don't, the corrosion will soon reappear.
I don't know why, but these damn terminals corrode worse than any I've ever seen. The connectors don't fit aftermarket batteries all that well and I suspect that has something to do with it.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Legend2TL
Motorsports News
Jan 31, 2016 09:27 AM
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
