Car won't start after 3 days of sitting.
Old Nov 20, 2012 | 10:17 PM
AbyssPearlTL's Avatar
This is a repeat occurrence by this point. I'm posting just out of curiosity. If my car sits without starting, the battery will be dead. Out of all the cars I've had, this is odd.
So, is there a way to trace what is draining my battery? Is this a common issue?
Input is appreciated.
Old Nov 21, 2012 | 01:05 AM
NC916's Avatar
Its most likely your HFL (hands free link) it drains your battery slowly so if you let it sit for 2-3days your battery will get drained. its an known issue just unplug your hfl which is located behind your dome light where you open and close your sunroof, or you can replace the part which is $700+. I left mines unplugged better then paying to replace it.
Old Nov 21, 2012 | 05:25 AM
omnuts's Avatar
2006 TL: WDP/Ebony
^Yep, definitely the HFL module is gone.. Check thru the MID if the hands free says 'booting up'.. Its a common problem.
Old Nov 21, 2012 | 09:12 AM
Manimal_Forever's Avatar
Had a similar problem, for me though it was the radio that had gone bad. Def check the HFL, but if that's not it, it may be the radio.
Old Nov 22, 2012 | 07:50 PM
Does anyone have a picture of what needs to be disconnected?
Old Nov 22, 2012 | 11:15 PM
nfnsquared's Avatar
Do a search in the audio forum or the service department. There is at least one DIY with pics that show the plug.
You can also pull the #6 fuse, but that will get old pretty quick.
Old Mar 17, 2019 | 05:39 PM
Cm4real's Avatar
Car want start
I actually replaced the handsfree link and the battery still drains after sitting 3 o more days. Any other suggestions?
Old Mar 17, 2019 | 06:30 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Old Mar 18, 2019 | 08:22 AM
Turbonut's Avatar
https://acurazine.com/forums/3g-tl-p...solved-973316/
Old Mar 20, 2019 | 10:35 AM
LoveMyTL-S's Avatar
Also may be the A/C relay. $6 dollar part and 1 minute fix.
Old Jun 6, 2019 | 08:05 PM
AgentSteel454's Avatar
The HFL is a very commonly documented issue with these cars.
Old Jul 1, 2019 | 09:52 AM
MBLiberty's Avatar
Manimal, how did you figure out it was your radio?
I already removed the radio in my 2007 TL Type S, and then tested the drain, and it was 1.2 amps. Then I disconnected the HFL, and the drain is now 0.55 amps, which still seems high.
Maybe I should remove the NAV and test again.
And then reinstall the radio, and test again.
What should the drain actually be?
Old Jul 1, 2019 | 10:09 AM
MBLiberty's Avatar
P.S. Looks like Turbonut got the drawn down to 14-16 mA after pulling the #7 fuse: https://acurazine.com/forums/3g-tl-p...solved-973316/.
So. I pulled my fuse, and then my meter showed 0.08 amps = 80 mA, which is much better than 550 mA, but not as good as 16 mA.
Feb 25, 2020 09:57 AM
jordanboi
Sep 5, 2015 01:33 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
