car was towed, now having trouble unlocking, starting, nav and radio lock
To anyone who can assist me, I thank you in advance.
Last Sunday my car (2007 TL-S) was towed (left my car overnight in a lot when I shouldn't have). I got my car back later that day, and it performed like normal. Monday in the morning, my nav screen asks me for a code, which I didn't have on me at the time. The next morning, I put in the navi code and all is fine. That evening, my remote won't unlock the doors so I unlock manually by inserting the key into the lock. I start the car like normal and find that my trip computer is reset, my navi is asking for a code, (after entering the code it is looking for new satellites), and my radio is asking for the code, which I enter. Today in the morning, my car unlocks with the remote like normal, I put the key in and all the lights come on like normal, radio plays, I turn the key to start the car and everything turns off and the car doesn't start. I have to open the door, close it, lock the car, unlock it (without the remote), and then when I try to start the car it starts right up, asking me for navi and radio codes, which I enter, and everything works fine (trip computer and navi is reset). This evening, same thing happens like this morning except the navi worked and it only asked for the radio code, but the trip computer was reset again.
My car was working fine until this week. I did a search last night on here (and now I can't find the thread again) and someone said in a thread about battery disconnection that you may have to enter the codes a couple times. Is this what they meant, or is this situation different? What's going on and is there anything I can do to resolve this? Is this worth a call to the dealer or should I just be patient? Thanks!
open the hood and check the battery terminals. See if they are on there securely. Also look for any crud buildup on the terminals. How old is the battery? You might want to take it to the dealer or autozone and have them check out the condition of the battery.
Thanks for your reply. Battery terminals are secure, no crud buildup. I don't know the exact age of the battery but the car is an 11/06 build and the battery hasn't been replaced.
My car has been working fine over the last few days and hopefully it stays that way.
Car Enthusiast
Those tow guys are careless, they don't care what kind of car is it. And probably the nicer car you have the more jealous they get, which they will abuse it even more when they tow your car. They may have pulled your car side way in a parrallel spot so they can tow, or towed your car backward. Those may have damaged your gear, axels, and who knows one of the sensor got knocked off. Anyway, gl with your ride man, if it acts up again jut bring to the dealer and have them check up for you..
I would be interested to know if they opened the car or not? I cannot for the life of me figure out what would be doing all that unless they opened the car and tried to stop the alarm from going off or something. My first and guess was the battery terminal thing or that was above mentioned or even a freak water leak but if they never opened the car I am at a loss. And that is rare.
how did they tow the car, they might have damaged a wire harness or something...
Thanks for the replies. I don't think they opened the car as they did not have keys and I see no signs of forced entry. The tow truck driver said he used wheels underneath my tires. I saw them next to my car when I picked it up. Since my last post, I have experienced several instances where the radio/navi/door locks/ignition in some combination do not work. The battery terminals feel tight. With that said, this morning when my car wouldn't start, I jiggled the positive terminal cable (it didn't move at the terminal) and my car started after that. It may have been a fluke that that worked but given that my problems are electrical in nature, I guess it wouldn't be a stretch. I will be tightening them for good measure when I get a chance and probably give my dealership a call to see if they can take a look. Would an inspection be covered under warranty?
Car Enthusiast
DO NOT keep the fact that the car was towed from the shop and tech!!!
Such info may be the cause of problem
They dont look for things to be warranty- they look for the problem, and if its warranty they do it on acuras dime
It may/should have sensors that detect when its at more than a certain angle- so it disarms the alarm when being towed,,,otherwise it would be going off constantly while on the hook
wiggle the batt cable? go to a parts store and ask for a free battery system test- they can tell if you need new cables or anything else
Does the owner book say anything about `when the car is towed`?
Perhaps my mistake can be a lesson for all of us: triple check the signs when we park somewhere.
Sorry to bump this old thread, but I write this in the hopes that it will help someone in the future. Although my battery cables appeared securely fastened to the battery terminals, about one month ago I tightened both positive and negative ends and have not had any problems since. Thanks csmeance, I should have just tightened them in the first place.
tman570
06-11-2019 07:56 AM
bearingman07936
01-07-2016 03:22 PM
handsom-hustla
11-13-2015 05:04 PM
andysinnh
09-05-2015 11:38 PM
