Car rough idle and other problems
Old Jun 22, 2020 | 11:41 PM
kobydc9's Avatar
9th Gear
So I have a 2005 acura tl automatic. when i start the car it has a rough idle until it finally settles out. The gas isn't very responsive at time so I'll give it gas and I can hear the engine rev a little before the car actually reacts. While driving I can't push the pedal down too far or else the car's rpm's will stop anywhere from 3200 to 5100. If i try to push the pedal to the floor the car automatically loses power and bogs out. I brought it to a shop and they told me the starting was due to my fuel pump going bad so that was changed. The problem was still there so they said it might be my throttle body so that was also changed and still no fix. I'm sorry if this has been covered before
Old Jun 23, 2020 | 04:05 AM
El_Cheapo's Avatar
Any codes?
Clogged exhaust?
​​​​​​The shop should eat the cost of throwing parts at it. This is known as "come backs". You can always open a dispute with the state's Bureau of Automotive Repair.
Old Jun 23, 2020 | 05:59 AM
kobydc9's Avatar
9th Gear
Originally Posted by El_Cheapo
Any codes?
Clogged exhaust?
checked the exhaust it was clear and no check engine light
Old Jun 23, 2020 | 08:55 AM
you or someone will have to go through the car very thoroughly. fix or replace anything that isnt up to OEM standards...meaning, if component is broken or beyond repair...replace it with brand new component...
so, check the fuel pump..since that's your starting point...check to see if it's receiving the correct voltage.
check to see if it's pumping.
check to see if it's pumping the required pressure.
Old Jun 23, 2020 | 09:21 AM
peter6's Avatar
If no codes El_Cheapo might be right. How did you checked the exhaust exactly? Muffler or cat falling apart internally can't be really seen unless you get under the car and start to take things apart.
Old Jun 23, 2020 | 01:08 PM
kobydc9's Avatar
9th Gear
yeah the fuel pump was checked and I'm getting normal fuel pressure
Old Jun 23, 2020 | 01:09 PM
kobydc9's Avatar
9th Gear
The cats were taken down and checked to see if clogged or bad
Old Jun 24, 2020 | 01:12 AM
kobydc9's Avatar
9th Gear
bump, any advice helps
Old Jun 24, 2020 | 04:01 AM
El_Cheapo's Avatar
You're going to have to look at live data on a scanner.
Old Jun 24, 2020 | 08:52 AM
youre gonna have to go through the car with a fine tooth comb to find the fault...could be anything
Old Jun 24, 2020 | 02:00 PM
csmeance's Avatar
more than likely APP sensor. You can't rev the car in park more than 5K RPMS
Old Jun 24, 2020 | 02:06 PM
El_Cheapo's Avatar
How should the APP be diagnosed to confirm?
Old Jun 24, 2020 | 03:19 PM
csmeance's Avatar
you can try monitoring the accelerator pedal sensor via a scanner tool and make sure the outputs match how much you are pressing the gas pedal. If not then replace the sensor. If you search here you'll find that it has fixed a few issues like yours.
Old Jun 24, 2020 | 08:24 PM
kobydc9's Avatar
9th Gear
I will give that a try, thank you
240sx acura tech
1G TL Problems & Fixes
Jan 29, 2015 12:49 PM
pBear
1G CL Problems & Fixes
Nov 11, 2012 08:01 PM
yoyoball
Jan 20, 2012 05:02 PM
mrsteve
Aug 13, 2004 06:40 PM
