car is idling weird
Old Jun 27, 2009 | 02:46 PM
itsnickONG's Avatar
car is idling weird
Hey guys, like the title says, my car is idling really weird. When I come to a complete stop at a light or the car is in Park, the RPMs still rise a bit past 1000 rpm. Normal cars idle around 900 rpm, but my car idles roughly around 1200 rpm. it goes up and down up and down, but it only happens at random times. Anyone know wats wrong?
Old Jun 27, 2009 | 03:04 PM
RonJonTL757's Avatar
Former Whyner
Up and down idle back in the day was always the TPS sensor (throttle positioning sensor) Not sure about our car
Old Jun 27, 2009 | 03:11 PM
scottDOTb's Avatar
from d.c. to tennessee
vacuum hose?
Old Jun 27, 2009 | 03:32 PM
phee's Avatar
I got the Shifts
i would check for a vacuum leak. it may also be your idle air control valve.
Old Jun 27, 2009 | 03:56 PM
VQPower37's Avatar
is ur ac on??
Old Jun 27, 2009 | 04:18 PM
JwongTLS's Avatar
sounds like its time to seafoam if u havent done so
it should make your idle more smooth.
GL
Old Jun 27, 2009 | 04:46 PM
csmeance's Avatar
Also when the car is fully warmed up, it should idle at around 700-800 RPM's, when cold around 1100 RPM's.
Old Jun 28, 2009 | 12:03 AM
itsnickONG's Avatar
Thanks for all the info! I'll take all the advice and get all that checked out.Thanks again :-)
Old Jun 28, 2009 | 06:49 PM
Inaccurate's Avatar
Was the car's battery disconnected for some reason, such as having your battery replaced ? If so, your car will idle weird for about two hours (of driving time) while the ECU relearns how to properly idle the engine.
Old Jun 28, 2009 | 11:57 PM
csmeance's Avatar
that's the idle re-learn, the proper procedure to do this is to let the car idle for 15 min. with any and all accessories such as radio and A/c turned off.
Old Jul 8, 2009 | 10:22 PM
cdp5095's Avatar
04 tl
GL
What exacty does seafoam do??? just wondering.. and is this good to do?? and where can i go to get it done?
Old Jul 9, 2009 | 01:31 AM
JwongTLS's Avatar
read this, this should help
https://acurazine.com/forums/3g-tl-2004-2008-93/seafom-experts-734776/
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
Papa Roe
4G TL Problems & Fixes
Sep 1, 2015 09:41 PM
