Can someone help me out??
So I been feeling someone engine movement and i can't seem to be able to figure out where it's coming from. I have the xlr8 mount upgrade. I brought my car to about 4 different shops and no one can figure it out. I start doing some looking around myself.. I took a pic if the lower tranny mount. Can someone tell me if there is suppose to be a bolt from this mount to the tranny.. ?? If you look behind the mount you can see the whole for the bolt... Idk if it's a random whole or not..
That's the rear transmission mount resting on your subframe...and most certainly NOT where it should be. Looks like you're going to possibly need to retap that hole.
The replacement bolt is 90167-SCV-A01, M10x97
That's certainly not the correct bolt that goes there. That assembly is:
BRACKET, TRANSMISSION MOUNT (UPPER)/ENGINE MOUNTS (MT) (-'06) for 2004 Acura TL
#24 is the bracket/mount assembly. (50863-SEP-A11 BRACKET ASSY., RR. TRANSMISSION SUB-FRAME)
You will need:
#25 50865-SEP-A01 WEIGHT, TRANSMISSION ASSY. (LOWER) (MT)
#29 50919-S87-A81 JOINT (3.5) (THREE-WAY)
You will need:
You will need:
You will need:
can you explain to me how you know that's now the correct bolt. just for my own information,
