'05 TL hid??
I know there are a lot if posts and I have searched but found nothing on my particular experience. 05 tl and my right side low headlight stopped working. So I replaced the bulb and got it all together and it came right on. I later drove the car and turned the headlights on and it didn't come on. I turned them off and on several times and it finally came on. If it comes on it seems to stay on but it only works maybe 1 out of every 10 or so time I cycle them on. Ballast problem?
What is others experience with this and what is the best fix?
Same happen to me, Check your ignitor 9/10 thats the part at fault. the ignitor is the harness between the light and harness. The hid requires a lot of starting voltage to "ignite"the light. Thats why it starts after serval attempts if it were the ballast 9/10 it wouldn't start at all.
swap the ignitor if the problem moves to the other side you have your problem.
Jul 16, 2017 07:33 AM
