'05 TL hid??
Old Oct 13, 2014 | 09:53 PM
alsims86's Avatar
Angry '05 TL hid??
I know there are a lot if posts and I have searched but found nothing on my particular experience. 05 tl and my right side low headlight stopped working. So I replaced the bulb and got it all together and it came right on. I later drove the car and turned the headlights on and it didn't come on. I turned them off and on several times and it finally came on. If it comes on it seems to stay on but it only works maybe 1 out of every 10 or so time I cycle them on. Ballast problem?
What is others experience with this and what is the best fix?
Old Oct 13, 2014 | 10:21 PM
dezymond's Avatar
Sounds like a bad ballast.
Try switching the bulbs and that'll help narrow it down a bit to the ballast and not the bulb.
Old Oct 14, 2014 | 09:52 AM
alsims86's Avatar
I had this same problem with the oem bulb so that's why I replaced it and still have the same problem. I still need to swap bulbs just to see?
Old Oct 15, 2014 | 08:51 AM
dezymond's Avatar
Well if anything that'll assure you didn't get a dud of a new bulb, but it does sound like a ballast issue.
Old Oct 15, 2014 | 09:52 PM
Purple ashes's Avatar
Check your fuses before anything.. I spent 200$ on ballasts and ended up being the under the hood fuse..
Old Oct 17, 2014 | 06:18 PM
JLT12's Avatar
9th Gear
Same happen to me, Check your ignitor 9/10 thats the part at fault. the ignitor is the harness between the light and harness. The hid requires a lot of starting voltage to "ignite"the light. Thats why it starts after serval attempts if it were the ballast 9/10 it wouldn't start at all.
swap the ignitor if the problem moves to the other side you have your problem.
Old Oct 21, 2014 | 10:21 AM
davedas90's Avatar
check for brake in wireing in the socket
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
