Can a bad alternator cause battery to drain?
Old Sep 10, 2013 | 05:29 PM
conboi's Avatar
So I'm trying to find out if i have a bad alternator cause i had to jump my car yesterday. The battery is still good but i think the alternator is either not charging the battery or its draining the battery. Checked the battery voltage level this morning and it was low at 12.3. What do you guys think is the main cause?
Old Sep 10, 2013 | 05:44 PM
flexcuff's Avatar
'04 TL....not stock
Yep, a bad alternator can absolutely drain your battery. The engine ends up getting it's spark from the battery instead of the alternator.
Old Sep 13, 2013 | 11:25 AM
hondaacurapro's Avatar
Check the battery voltage when the car is running, it should be close to 14 volts. This is not a perfect test, but if the alternator is only producing 12.5-13.0 volts it is probably the problem.
Old Sep 13, 2013 | 11:29 AM
except that a parasitic draw usually comes from a bad HFL unit. which is commonly the root of a drained battery in the TL's
Old Sep 13, 2013 | 11:53 AM
HFL parasitic draw does not kill a battery overnight. Most people that have HFL draw don't even know it because they drive the car every day. Read his post again, and see what he asked.
Old Sep 13, 2013 | 12:40 PM
vietxquangstah's Avatar
if the alternator was bad wouldn't the red battery light be illuminated on his dashboard?
Old Sep 13, 2013 | 12:43 PM
it killed my battery overnight. just saying.
Old Sep 13, 2013 | 04:28 PM
EvilVirus's Avatar
OP doesnt even know that. He is just throwing what could be the culprit. In OP's case, the HFL could be the culprit, but I do agree with you to check the voltage on the battery while runing first before going any further.
jdmaszfcuk
Oct 19, 2015 12:31 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
agupta3224
Sep 22, 2015 08:08 PM
