A/C pulley help
Old Feb 13, 2016 | 07:47 AM
leerbgdup's Avatar
A/C pulley help
So the ac pulley broke off the compressor. The belt came off, so no p/s and the alternator isn't running. So I need to get my car to the Acura dealership which is bout 70miles away. Is there a belt I can get to bypass the ac to drive it to the dealership? It's an 04 TL. I'll post up some picks later from my phone, never seen anything like this... Started my making a winding and grinding noise then it stopped and the battery light came on and p/s went out.
Old Feb 13, 2016 | 09:05 AM
Turbonut's Avatar
With the way the belt is routed, looks like a smaller belt coming off the idler than around the balancer would work in a pinch, but length is unknown. Move the tensioner outward and wrap a tape around the routing to get an approximate length, then when the tensioner is released it should tighten the belt.
If it's headed to the Acura dealer, hope the bank account is healthy. The A/C compressor/clutch is around $700 while aftermarket units $150/$250, plus the labor and other small parts.
Good luck
Old Feb 13, 2016 | 10:07 AM
leerbgdup's Avatar
Good luck
Yea that's what I'm thinking to do. I tried searching for a tread I thought I seen awhile ago. Someone had used a smaller belt and removed the ac. But no luck finding it. lol yea man I what your saying they wanted $700 to replace an axle because my warrenty wouldn't cover it due to my modified suspension but they'll cover this since under the hood is all stock
Old Feb 13, 2016 | 12:22 PM
nfnsquared's Avatar
69.5"
https://acurazine.com/forums/third-g...t-size-940996/
nx04
Jan 20, 2022 06:14 AM
OK_TL04
1/2G MDX (2001-2013)
Feb 9, 2016 08:40 PM
CrazyEights
Feb 1, 2016 03:02 PM
Gigolo
Jan 22, 2016 10:28 AM
wj4
2G TSX Problems & Fixes
Jan 11, 2016 08:12 AM
