'04-'08 TL A/C Delete serpentine belt size
Hello all,
I will be doing an a/c delete compressor, all hoses, tubes etc...
has anyone done this and would know what size serpentine belt or the part number of said belt would be needed for the delete
thank you
didn't find much searching just some simple drawings of how the belt would be rerouted
thank you
Im not sure of the belt size but this might help. get a string and wrap it around the pulleys.
Then measure the string and minus a couple of inches of slack for the tensioner
bluetl04 (01-18-2016)
AZ Track Whore
if only someone has done this...
https://acurazine.com/forums/perform...ssible-801520/
https://acurazine.com/forums/perform...delete-797034/
nx04 (01-24-2016)
i seen you are using a 69.5 inch belt is that perfect so far?
I will list the belt I used below, got it right from Advanced Auto. I'll list a cross-reference chart for equivalent belts as well. A tip to get this snug fitting belt on is to get it on track with all the pulley's and guide. You want to get it mostly on, around the crank, bottom guide, alternator. Then about 3/4 of the belt width on the auto-tensioner and then push it up over the edge of the power steering pulley side wall. Keep pushing it on the point of tension at the power steering side wall until it pops into place up over the edge. It's a MF'r for sure. But hey, I'd rather have it snug then loose, not sure if they make a 70" belt.
Dayco
Poly Rib Belt, Premium - Engineered to conform to high mileage, worn or misaligned drives Part No. 5060695 Warranty: 3 YR REPLACEMENT IF DEFECTIVE
AUTOMOTIVE BRAND INTERCHANGES:
- ACDELCO 6K695
- CHRYSLER 4891 875AA
- CONTITECH PK060695
- DAYCO 5060695
- Dodge 4891 875AA
- FORD F87Z 8620-HA
- Gates K060695
- GMC 14092210
- GMC 24508560
- GMC 88986806
- GOODYEAR 4060695
- Inches 695K6
- NAPA 6PK1765
- NAPA Belts/Hose 25-060695
- PORSCHE 9A1 102 218 00
- Volkswagen 7B0 903 137 A
jamestheunderdog
10-23-2016 06:38 PM
