A/C Compressor issues
Old May 30, 2013 | 11:54 AM
Rotation0220's Avatar
8th Gear
My A/C was not cooling but discovered that the refrigerant (134a) was completely empty. Recharged it and when the TL was sitting still, it was kicking out cold air so I thought the problem was solved but after driving the car the A/C would go from cold air to room temp air and then back to cold air. I noticed that when sitting still the compressor would kick on and off in quick spurts. Sometimes the compressor stays on for a while but then it goes back to kicking on and off. Im wondering if my compressor is going bad or if I may just have a leak? I was also wondering if anyone had a maintenance diagram of the system so I could so alittle trobleshooting or even be able to remove the compressor if that is the problem.
Thanks in advance!
Old May 30, 2013 | 06:40 PM
YeuEmMaiMai's Avatar
you over charged it. The car has a high pressure cut-out switch
Also, you also got a leak that you need to find and repair. typical leak area are condensor and compressor seals followed by o-rings.
Old May 30, 2013 | 07:42 PM
pohljm's Avatar
it was empty and your wondering if you have a leak??? WTH. thanks for polluting the environment with another wasted charge of refrigerant.
Old May 30, 2013 | 07:53 PM
don't get your panties in a bunch, he would have to recharge it with a dye to find the leak anyways...
OP the reason I say you have a leak is that my 1994 accord did not require an A/C recharge until 2002 or about 9 years after it was bought new. It had a tiny leak in the condensor. my 1998 accord still had great cold AC at 8 years old when I sold it and my 2002 CL-S had great cold A/C until it's accident in 2009 when they replaced the non oem condensor with a cheap aftermarket part. It failed less than 2 years later so I replaced it with an Acura OEM one and it's been great ever since.
01CLOwner
Oct 9, 2015 01:07 PM
jdm_94-07TypeS
Oct 7, 2015 11:14 PM
lovic87
Sep 15, 2015 06:07 PM
KillerG
Sep 4, 2015 02:02 PM
dlknight
Sep 3, 2015 07:54 PM
