buzz when turning ignition key??
Old Apr 1, 2023 | 01:29 PM
B Sc's Avatar
Anyone with a 2004 TL ever hear this?
The sound of what I can only describe as a mechanical insect 'buzz', when turning from OFF position through to starter activation. From inside the steering wheel housing.
Its irregular. I sometimes can recreate the sound TURNING SLLOOOOOOWWLY from OFF to BATT, most times its just so periodic I forget about it until it happens again.
It doesnt sound like arching, almost sounds like a module in a cellphone or a gaming controller that causes the vibration
Odd, but should I be worried or anyone else experienced and know what it is?
Old Apr 1, 2023 | 03:01 PM
Tyrone503's Avatar
CDM
More than likely its the steering switch causing the noise you're hearing. Part # 35130-SAA-J51
Old Apr 1, 2023 | 06:19 PM
BillMFD3's Avatar
Second that. I had a similar issue where the start relay would buzz and occasionally car wouldn’t start. It was the ignition switch.
Old Apr 10, 2023 | 02:18 PM
B Sc's Avatar
Question but is it a prob?
Is it a prob though?
Have you experienced this and it led to something, if what then what? Steering column fire? (sorta sarcasm)
Not to be a bit tired of fixing things all the time but "turning the key as fast as possible" and avoiding the buzz, is what Im hoping to hear, LOL
Got the wheelwell fender lining, HID bulb replace (HORRIFIC BLOODY HASSLE JUST TO REPLACE A BULB! TAKE FRONT QUARTER OF CAR OFF TO DO IT??), and forgot what else... after last years front end fixing in the dead of winter after that deer humped the front of my car at 110 kmph, kinda want to go back to hobbies I used to enjoy instead LOL
Old Apr 11, 2023 | 03:03 PM
BillMFD3's Avatar
My post from an old thread about this issue:
+1 for Ignition switch - the buzzing is the start path relay that as stated above is not getting enough voltage to stay up so it oscillates back an forth. Replacing the ignition switch cost me $28 (Beck Arnley part form Rock Auto) exact match and probably an OEM manufacturer anyway...
The procedure is mentioned elsewhere as well:
Disconnect Battery
Remove three phillips screws on bottom of steering wheel cover.
Press in along on the top part of the cover seam to split it open and remove
Remove plug to ignition switch
Remove two phillips screws to switch
Slide out old and slide in new switch.
Reverse order to finish up.
I opened up the old switch - the copper contact surface looked suspect...
Gigolo
Dec 1, 2012 07:02 PM
r3n3gad3II
Aug 15, 2011 12:06 PM
detch
1G TSX Problems & Fixes
Jul 11, 2011 03:18 PM
Acura02Gold
Jun 6, 2006 03:19 PM
wontonjohnny
Jan 8, 2006 04:13 AM
