Burnout lurch
Old Jan 9, 2020 | 07:57 AM
Willcmartin's Avatar
Burnout lurch
So I’ve recently had a stage 1 clutch installed on my 2007 Acura TL type s and I’ve broken it in and all that. So when ever I go and do a burnout in first gear and bang the limiter a couple of time it starts lurching really bad it doesn’t feel mechanical more like a safety system I obviously have traction control off so what could be causing this? It’s so bad when it happens I have to stop or I think I’m gonna break something.
Old Jan 9, 2020 | 08:39 AM
well, Yes. the car is not intended for burnouts. you are damaging the car. you are abusing it. Keep abusing it and it will break.
Old Jan 9, 2020 | 09:19 AM
BreezyTL's Avatar
Old Jan 9, 2020 | 10:04 AM
twokexlv6coupe's Avatar
No way- a safety system is kicking on when you're doing something unsafe?? Do tell more....
Old Jan 9, 2020 | 10:11 AM
keep banging on the rev limiter a couple more times, it's just getting started
Old Jan 9, 2020 | 03:16 PM
Yvuru's Avatar
Have you tried removing the rev limiter?
Old Jan 9, 2020 | 09:39 PM
Jackass's Avatar
Is it lurching because you are still banging off the limiter? Or are you getting excessive wheel hop which is causing the lurching?
I don't think I have ever bounced off the limiter on purpose in the 11+ years I have owned my TL. No matter what....your poor TL won't last long if this is how it is going to be treated.
Old Jan 10, 2020 | 01:41 AM
WDPanda's Avatar
Have you tried removing the driver?
Old Jan 10, 2020 | 09:54 AM
GhostTL09's Avatar
Whenever I read threads like this I always look to see the age of the driver, and if age is correct he will probably be broken before the TL breaks.
OP probably just finished watching Tokyo Drift lol
Old Jan 10, 2020 | 10:35 AM
Jackass's Avatar
I did this same stuff back in my early 20's. I didn't have a car anywhere near as nice as the TL. I did all of this stuff in my Z24...and ended up shattering the spider gears in the differential and broke an engine mount.
To the OP....just be aware of what you will be breaking and tearing up. If you are aware and OK with that...have fun and be safe. My guess is you having major wheel hop which is extremely disturbing to feel in the cabin as well as quite destructive to the vehicle.
Russell Peters
Dec 5, 2016 10:50 AM
mwmcdonald
Apr 28, 2014 08:28 PM
Jase13
Jan 11, 2014 10:15 AM
JTS97Z28
Jul 25, 2011 01:05 PM
REDLINERAV
Oct 15, 2009 06:35 PM
