Bulb or Ballast?
Old Feb 28, 2011 | 10:34 AM
d1rtd1ver's Avatar
Bulb or Ballast?
Hi guys,
I normally just read and haven't really taken the time to post before. But now I have a technical ? for you all.
My passenger HID is acting funny and I'm unsure if it's a ballast issue or a bulb issue. Here's the problem: I turn on the headlights and they come on just fine, then within 5 minutes the light starts going pink / purple and then eventually the passenger bulb shuts down.
Do you guys think it's the Bulb going out or the ballast? I would think if it were the bulb it wouldn't light up at all but I don't know enough about HIDs to form an educated opinion.
Thanks for your time guys!
Old Feb 28, 2011 | 10:43 AM
nfnsquared's Avatar
As far as I know, "pink-eye" indicates a failing bulb...
And due to shift, it's generally recommended to replace both bulbs at the same time.
Old Feb 28, 2011 | 10:51 AM
Flipster23's Avatar
Pink means your bulb is taking a crap..
check out our vendor section for new bulbs
Old Feb 28, 2011 | 12:52 PM
d1rtd1ver's Avatar
Thanks guys. I do appreciate the info. Will be grabbing a new pair of bulbs. What do you guys think of the Phillips D2S CM (Color Match) bulbs?
Old Feb 28, 2011 | 12:58 PM
SatinSilverAV6's Avatar
2003 Accord Coupe V6
Yes its probably your bulb. It it is a ballast usually you will see a flickering HID.
Old Feb 28, 2011 | 01:07 PM
nfnsquared's Avatar
Can't really help you there, still on my original lamps. There are several good threads on headlights. Do a search and you should find enough opinions to keep you busy for a while....
hashbrown
Feb 18, 2022 11:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
Juandiablo
Sep 27, 2015 10:32 AM
