Broken Engine Mounts question
Old Sep 30, 2011 | 11:50 AM
Houston's Avatar
Here I come!
My engine mounts have been broken for a while now. I'm about to replace them, but I'm aware that other parts could have been damaged from the engine movement. My question is... Does anybody know what parts?
I want to inspect everything while I have the car on the lift. Any ideas?
Thx in adavance.
On a side note...My tranny would jump out of gear while stoping or making turns. This whole time I thought it was the trans, but turns out it's been the mounts this whole time....
Old Oct 1, 2011 | 09:51 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
When you shift to reverse do you feel any vibriations or noise coming out, or over speed bumps feel other movemnts ... i just changed my front motor mount and that fixed my problems...
Old Oct 1, 2011 | 11:00 PM
SpiderX1016's Avatar
Do you have a 6MT?
Old Oct 2, 2011 | 01:10 AM
NMG-4's Avatar
maybe this help.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Oct 2, 2011 | 01:17 AM
Originally Posted by SpiderX1016
Do you have a 6MT?
no, he's 5AT
Old Oct 2, 2011 | 11:29 PM
eg5's Avatar
eg5
user title goes here
make sure those transmission lower mounts are still good. also a common failure are those subframe mount/bushing brackets. they're located on the subframe and bolt up to the vehicles frame.
well the obvious also,like the rear mount. and check the bracket for the side mount. that one contacts the mount assembly causing a bad strut sound when going over bumps. but if you have access to a lift,im sure your teachnician will provide you with a thorough inspection.
Old Oct 3, 2011 | 10:20 AM
Houston's Avatar
Here I come!
^^ I'm the technician.... I just bought the XLR8 mounts and engine torque damper combo so I'll be replacing all mounts. I was planning on checking the tranny cable link to see if it's bent. I'll definitely check those bushing brackets and tranny mounts.
Sorry for the delayed response and thx for your responses. If anybody has any other suggestions, I would appreciate the input.
Old Oct 5, 2011 | 02:50 PM
justen's Avatar
I will be replacing mine soon as well. I am looking for a DIY on here but haven't found it yet. I dont have a lift so I'll be using jack stnads. do you think I am going to run into an issue?
Old Oct 5, 2011 | 06:46 PM
Houston's Avatar
Here I come!
^^ I hope you didn't take the me being a technician seriously..lol. I just meant that as, i'm the one doing the job. I'll be using my buddy's lift, but I think you should fine on the ground. It looks pretty simple.
Old Oct 6, 2011 | 06:13 PM
Ricky Pounds's Avatar
B A N N E D
Follow these instructions flawlessly!! I did all these changes, the car's improvement was of a 100% for the best!!
Old Oct 6, 2011 | 08:19 PM
gatoferoz25's Avatar
Bro please post some more specific info about swapping this motor mounts cuze am running with the same problem thx in advance
Old Oct 27, 2011 | 05:38 PM
mnjeepmale's Avatar
How many parts here? Would you know the part numbers so I can order these and get this done? '06 TL A/T
Old Nov 8, 2011 | 10:34 AM
Jose Gomez's Avatar
I need to change that front motot mount as well... Does any one know the part number to that one motot mount?
Old Jan 15, 2012 | 07:44 AM
06NH6MTTL's Avatar
i recently installed my xlr8 75a mounts with the exception of the rear because one of the bolts holding it to the sub frame was seized but there was a huge improvement in feel because both my front and side were completely shot. The install is simple but not easy with the stiffer mounts, requires a lot of push and pull to get the holes to line up. Job should be done on the ground as well !
Old Jan 15, 2012 | 01:07 PM
swoosh's Avatar
takin care of Business in
look into Innovative Mounts or XLR8 mounts....
I have Innovative 60A and am very very happy....60K and riding....but yeah the vibrations do get to me....i call it a back massage.....
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
