Breaks Squealing after change. What do you think?
Old Apr 11, 2011 | 06:46 PM
hleapha's Avatar
I changed out the front brake pads on my '05 Base AT TL about 6k miles ago and they have been making an audible squeal right before I stop. They have done it in a similar fashion since I changed them. I waited to make sure it wasn't just some grit or imperfection on the pad. I got Wagner Thermoquiet ceramics. Now, I know they aren't stock or the championed Duralast CMAX gold, but I know that properly installed pads shouldn't squeal. Its Wagner, not generic crap. That leads to me to thinking it was my installation.
Took everything off with care and cleaned off the parts okay with break fluid cleaner. I greased the new shims and put them back in. I had flushed the lines previously. I think I didn't re-grease the shins well enough. I used some Bio shit grease that was on sale at Lowes. I'm just going to redo the break job with some better grease, clean them better, reinstall them properly, and bleed the brakes.
Anything else that you can think of?
Old Apr 11, 2011 | 07:34 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
did you bed the pads into the rotors??
i believe heeltoe has a nice article describing the process and why it needs to be done.
Old Apr 11, 2011 | 09:08 PM
hleapha's Avatar
Honestly, I can't remember. I remember doing ABS stops after bleeding my brakes, but I don't remember when I did the pads. What is the process you go through with our TL's to bed?
Old Apr 12, 2011 | 09:44 PM
eg5's Avatar
eg5
user title goes here
install oem pads for under 70bux, problem solved.
...install lube to the corners of the pad where they sit on the caliper
Old Apr 12, 2011 | 11:44 PM
Dino81's Avatar
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
I would have done rotors too, not just a pad slap.
lanechanger
Oct 13, 2015 10:56 AM
2012wagon
Sep 29, 2015 04:21 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
joflewbyu2
Sep 23, 2015 11:16 PM
