Braking Issue
Old Sep 25, 2008 | 04:05 PM
Ni$h21's Avatar
1 quarter mile at a time
Braking Issue
When I slow down from 50 to 0 the car begins to pull sharply either left or right around the 20-30 mph mark, any clues as to what this is, i also have squeaking when i hit the breaks
Old Sep 25, 2008 | 05:54 PM
TeknoKing's Avatar
If it pulls like that it could be the following:
a) warped rotors & bad brake pads
b) alignment is way off
c) bad tire tread
d) could be the cv-joints
e) etc...etc...
Does your steering wheel vibrate when braking?
Old Sep 25, 2008 | 06:11 PM
MrHeeltoe's Avatar
Former Sponsor
c) bad tire tread
e) etc...etc...
Good points...my counter points
a) warped rotors & bad brake pads - No, that would manifest as shaking in the steering wheel and would not cause a pull.
b) alignment is way off - This is my answer too, except it need not be way off...just off enough that when the front is under compression a little the car pulls. I'd bet this is it or....
c) bad tire tread - irregular tires. One tire could be causing the pull.
d) could be the cv-joints - No, would not be this
e) etc...etc... - besides a messed up control arm or bushings, I am not sure what else it could be
Rotate the front tires left to right (as long as they are not directional) and see if the pull moves or goes away. If the pull changes, its a tire problem. If the pull stays the same, you need a new alignment.
Marcus
Old Sep 26, 2008 | 02:18 AM
Ni$h21's Avatar
thanks guys and alignment does start to sound right
tires i got brand new during the summer, and i don't think i've had an alignment done in a good while
appreciate it
Old Sep 26, 2008 | 11:21 AM
01tl4tl's Avatar
how are the actual brake pads and rotors= is there is equal pad and rotor wear- no indication of sticky caliper?
Whenever you buy new tires- ALWAYS get a 4 wheel thrust alignment!!!
Driving on Earth throws things out of whack, and you want to protect your new tires- and get max performance and mileage from the car---right??
Alignment that is toe-out makes the car try to split in 2, not great for fuel economy
Old Sep 28, 2008 | 11:37 PM
240sx acura tech's Avatar
acura master tech
most likly the calipers are locking up and the slide pins are not lubed up , binding.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
jliu6789
Sep 8, 2015 08:02 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
