Brakes
Old Jun 27, 2010 | 02:51 PM
narnia's Avatar
Team SSM Queen
Brakes
My car hit 105K (and has been trouble free all this time! ) and I still have the original brakes and pads since I do almost my driving on highways. I drive about 30K a year now, and plan on keeping the car another 2 years.
When I have my tires rotated, I'm going to ask the guy to check the pads for wear. My question is - if the pads are worn, should I go ahead and put new brakes on too, since I'm going to have to do this eventually?
I've never owned a car this long. How can I tell if I just need new pads or also need new brakes?
Old Jun 27, 2010 | 03:47 PM
Will Y.'s Avatar
Registered but harmless
When people refer to "new brakes," they usually mean the brake pads.
The rotors/disks (which are gripped by the pads to stop the car) sometimes have to be changed if they have worn thin or unevenly, have deep grooves/scoring, etc.
The brake pads each have slot/groove that, like tire treads, can be viewed to determine how much wear is left.
Have the person rotating your tires show you-- it's easy.
The rotor wall thickness can be measured by the tech/mechanic.
Usually, at each service or inspection, the mechanic will say or write on your paperwork how much wear remains as a percentage of remaining pad (they refer to the most worn pad); rotor thickness is usually not checked unless there is a problem or when new pads are needed.
I would not change pads unless there is less than 25% remaining.
Old Jun 27, 2010 | 06:42 PM
narnia's Avatar
Team SSM Queen
Thank you Will Y.!
Old Jun 28, 2010 | 12:31 PM
01tl4tl's Avatar
as a retired tech--we didnt measure pad thickness- we guess-timated percentage--it looks like it needs brakes today or it doesnt..I got things to do
You cant truely measure the pad unless you remove it--
for visual without removing caliper, the center vent line-if present-not all pads use one-- has its bottem as the min thickness
BUT
pads can be worn out on the face and still have depth
the minimum pad thickness is 2mm and age plus low thickness equal less effective braking
Yours are probably glazed and cracked by now= buy some new pads
Have a brake shop--not a big brand name place with corp minimums to earn on every car- a smaller private owner honest shop- ck the rotor condition
Acura rotors are not very good for resurfacing--it they get gouged and need to be cut- they get too thin and get shake easily
Old Jun 28, 2010 | 12:32 PM
01tl4tl's Avatar
you are way overdue for a brake fluid flush too
Old Jun 29, 2010 | 09:54 AM
narnia's Avatar
Team SSM Queen
Thank you 01tl4tl, you are always an amazing resource!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
