Brake switch
Old 07-13-2013 | 06:46 PM
Gil'sUA5's Avatar
Brake switch
05 TL my shifter will not shift out of park no matter how hard I hit the brake. I replaced the brake switch today and still have the same issue. This is extremely annoying i have to manually unlock the shifter with my key every single time i get in the car.
Old 07-13-2013 | 07:21 PM
Vlad_Type_S's Avatar
Registered Bike Offender
AT problems. Isn't it required to have the key inside the ignition before you can shift out of park?
Old 07-14-2013 | 12:39 AM
Gil'sUA5's Avatar
The key is in the ignition while i unlock the shifter with my spare key my brake light/horn fuse blew so i know about that issue but didnt think that had anything to do with the car not shifting out of park specially with a new brake switch.
Old 07-14-2013 | 12:42 AM
Gil'sUA5's Avatar
Today my brakes locked up on me and the car wont accelerate and i can smell my brakes burning and my brake pedal is very hard, could this be related?
Old 07-14-2013 | 02:08 PM
Yeah definitely sounds related.
When this all started, were you able to press the brake pedal down all the way?
Old 07-14-2013 | 04:49 PM
Gil'sUA5's Avatar
No, soon as it started the brake pedal started getting hard now its like a rock and the car wont even accelerate and smoke comes out of the front wheels. Im thinking my calipers are no good but i dropped it off at the shop so they'll be checking it out first thing tomorrow morning.
Old 07-15-2013 | 04:57 PM
I guess we'll see. Report back when you find out!
Old 07-15-2013 | 11:52 PM
Gil'sUA5's Avatar
The brake switch was intalled incorrectly which ended up partially applying the brakes at all times so my mechanic installed it correctly and it now works fine. Also my horn/stop fuse was blown so it was replaced i hope it doesnt blow again because that would mean i have a short and will involve further diagnosis but so far so good 2 days and no issues yet car shifts out of park fine brake lights work and horn sounds.
Old 07-17-2013 | 06:30 AM
Project_CLean's Avatar
MMkay.
Nice!
Old 07-17-2013 | 08:11 AM
Gil'sUA5's Avatar
Now after using the horn a few times my horn/stop fuse has now blown for the 3rd time so i am back to square 1 no brake lights, wont shift out of park, and horn wont sound.
Old 07-17-2013 | 11:49 AM
Well, the reason that a fuse blows is a high electrical current draw. The only reasons for a high electrical current draw would be an intermittent short, or a failed component with an intermittent short. The reason the trans won't shift is because the brake lights don't work. It's a safety feature.
Give these threads a read:
https://acurazine.com/forums/2g-tl-problems-fixes-117/03-acura-tl-stuck-park-848345/
https://acurazine.com/forums/2g-tl-1999-2003-98/tl-stuck-park-gear-685976/
Also: https://www.google.com/search?q=wont....acurazine.com
Then, check all of your fuses. Good luck.
Old 07-17-2013 | 10:24 PM
Gil'sUA5's Avatar
https://acurazine.com/forums/showthread.php?t=848345
https://acurazine.com/forums/showthread.php?t=685976
Ive read all of those threads already, i am going to take it to an electrician tomorrow and hopefully he can find this short.
Old 07-19-2013 | 10:58 AM
Gil'sUA5's Avatar
Just got the horn/stop fuse short fixed now my fuse no longer blows BUT my VSA warning light is still on, the VSA light itself is no longer on but the warning triangle is still on hours after getting thr car fixed. The electrician told me to drive the car that the warning triangle will come off but im not convinced.
Old 07-19-2013 | 12:36 PM
Gil'sUA5's Avatar
VSA light just came back on, before when i put a new fuse in after the first one would blow the VSA lights would come off and everything would work perfect. Now that i got the car fixed properly and fuse is not blowing the VSA lights stay on.
Old 07-21-2013 | 12:11 AM
Gil'sUA5's Avatar
Bump for some help, VSA light comes on a few minutes after i start driving the car.
Old 07-22-2013 | 01:00 PM
Do you also have a check engine light?
Old 07-23-2013 | 12:01 AM
Gil'sUA5's Avatar
Nope, the check engine light on my car has never come on while ive owned it. Yesterday i took it back to the electrician that fixed the short and he cleared the VSA light. Ive been driving the car since and it hasnt come back on so hopefully it stays like this but now im scared to press the VSA button to see if it works because the light might come back on lol
GWEEDOspeedo
01-15-2016 10:39 PM
rockyboy
10-02-2015 10:45 PM
xsilverhawkx
09-28-2015 06:51 PM
2ManyHobbies
09-24-2015 09:23 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Brake switch
