brake problems!!! just concerns..
Old Sep 28, 2006 | 08:41 PM
badboy4life1169's Avatar
lately ive been hearing screeching noises from my brakes? i usually roll with the windows down after school and when the music is low, and i come to a complete stop my brakes make a really screeching noise, its not loud, but its fuc**ng annoying, should be concerned?? i dont know much about the technical parts of the 05 TL haha, im only a senior in hs. but are my brakes fading??
05 AT TL
27,000 miles
never worked on brakes before
Old Sep 29, 2006 | 10:56 AM
Ron A's Avatar
Administrator
It may be the wear indicators doing their thing and telling you the pads need to be replaced. Although this shouldn't happen at 27,000 miles, it is also dependent on the type of driving that you do.
We don't have too much problem with brakes screeching on 5AT cars, so you should get the pads checked. You can look in through the wheel openings and see the calipers, but if you don't know what you are looking for you won't know for sure what the condition of the pads is, so a trip to the dealer or any shop that you trust would be a good idea.
Old Sep 29, 2006 | 04:31 PM
ACTROS's Avatar
DER NEUE ^
I have the same thing happening to my 04 AT with 12K miles (it started at 8K) mostly when brakes are hot, coming to a stop or decellerating. I noticed that if I break harder the screeching goes away. It's definitely coming from the front brakes and I think it's the right front. In general I think the rotors and calipers on AT cars are barely enough for a car this fast and heavy. At only 5K my brakes looked like shit, the rotors grooved and corroded, constant brake dust, noise and vibration when braking,etc. I must confess I didn't change the brake fluid yet though which you suppose to do ever 3 years, that could be part of the weak brakes problem.
The best solution in my ipinion would be to to replace the stock rotors and pads, and change Honda brake fluid for fine aftermarket products out there. As far as I know most Honda brakes and tires were always not on par with the rest of the car if only they could change that!
Old Sep 29, 2006 | 04:35 PM
oh okay thanks, well ive only had my car since april 05. so its only been a year and a half, but ill definitly get em checked out. ive actually painted my calipers blue, but that was a good 2-3 motnhs ago, do you think it may be coming from that??
Old Oct 2, 2006 | 10:42 AM
tzakiel's Avatar
Cold Racketeer
I also have squeaking brakes. 05 AT. Asked dealer to look at it 2-3 times now and they always say they don't hear it or see any wear problems.
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
