Brake problem?
Old Oct 13, 2014 | 12:47 PM
Rigoman1's Avatar
Brake problem?
I'm not sure what it is but it happens on a hard brake. I had to do a hard brake cause of traffic ahead of me and when I did i could feel on the pedal and hear like a metal grinding noise like if gears or something we're sliping. I also noticed it if I slightly brake when I pass a bump. Anyone know what this is?
Old Oct 13, 2014 | 04:16 PM
ds03's Avatar
Time to replace your pads (sounds like down to the rivets on one of them). Let it go much longer and you may be out rotors as well.
Old Oct 13, 2014 | 09:04 PM
Rigoman1's Avatar
I have new pads and rotors though. Like last month new
Old Oct 13, 2014 | 09:05 PM
Rigoman1's Avatar
And it did it before I replaced them too if you were thinking i put them on wrong
Old Oct 14, 2014 | 02:57 PM
ds03's Avatar
Did you replace all 4 sets? If not, could be the sets you didn't replace? Caliper hanging up? Dust shield bent? Otherwise I'm at a loss
Old Oct 14, 2014 | 03:34 PM
pbook4g5's Avatar
Sounds like ABS is working, honestly. Nothing to worry about.
Old Oct 14, 2014 | 03:53 PM
Rigoman1's Avatar
Could be, but it just sounds and feels like something is falling apart
Old Oct 14, 2014 | 08:28 PM
ds03's Avatar
The part about hearing/feeling it even when slightly braking wouldn't make sense though if simply ABS kicking in.
Old Oct 14, 2014 | 09:55 PM
pbook4g5's Avatar
slightly braking over a bump would cause ABS to come on, too.
Old Oct 17, 2014 | 12:04 PM
wawa2010's Avatar
Which rotor and pad you installed? A cheap rotor could cause noise or shake. Then i replaced the rotor after 6 months with a little expensive one, I remember it is called Wagner something (about $75 compared with previous $45 one). Now everything is working fine and I am happy with it.
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
