Brake problem
Old Jun 23, 2011 | 03:05 PM
foosh2369's Avatar
Brake problem
I had to change the rear brake pads and had the rotors turned. We have bled all four of the lines and got all of the air out and until new fluid was running thru, but I still don't have a full pedal. When I brake hard the ABS doesn't kick in either. Called a couple of shops and they mentioned that the system may need to be "pressurized"? Any suggestions?
Old Jun 23, 2011 | 06:57 PM
Turbonut's Avatar
Well, there shouldn't have been any air in the system from just changing the pads and rotors, so if bled, I'd check that it was done properly, proper sequence and right bleeding method. If a M/T or TL-S, there are 2 bleeders on each front caliper, 1 on each rear.
Possible that there is air in the system so not a firm pedal therefore the ABS won't kick in as the brakes aren’t strong enough to lock up any wheel/tire.
When they speak of "pressurized", I'm assuming that they are referring to bleeding the system by pressurizing the system through the master cylinder, but an effective bleed can be done manually, if done correctly.
Old Jul 6, 2011 | 05:44 PM
alex7's Avatar
What is the correct sequence ? I have a base 05 and am about to do this .. thanks .
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
