Brake pedal sensitivity
Old Sep 2, 2010 | 09:57 PM
chasingthecool's Avatar
it seems like mine you have to push down on the pedal a little harder than usual to stop. can you fix the sensitivity on the brake pedals. on my 07 civic i barely tap it and it brakes (which i like better)
Old Sep 2, 2010 | 10:18 PM
blkaspec's Avatar
Full of water...
how old is the car? how long have you owned it? when was the last time the fluid/pads/rotors were replaced?
i love how my brakes feel, but i have never driven a Civic so i cant compare.
Old Sep 2, 2010 | 10:21 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You might have to bleed the brake lines. Or, your pads are worn. Or, you need to rebed the brake pads.
its a 08 with 29k
Old Sep 2, 2010 | 10:24 PM
AMUA6's Avatar
ScoobyZINE
Old Sep 3, 2010 | 01:23 AM
do any of ya'll feel like the brakes are kind of weak?
Old Sep 4, 2010 | 10:05 AM
I hate cars's Avatar
They have always felt normal to me. Remember, it's a 3,500lb car, not a 2,900lb car. They can make the brakes feel anyway they want but most people that buy TLs don't want grabby brakes.
If everything is in good working order (no air in the lines, booster is working fine), try some different pads.
If you can find pads with "GG" in the part number they will be much more powerful for the same pedal effort. Stock pads are "FF" which is the friction coefficient cold and hot. The only issue is finding a GG pad that's not a full race pad.
Hawk HP+ would probably be the least aggressive, most street friendly GG pad.
My Rotora H6 pads are on the very high end of a GG rating. they're almost a GH pad. If you can get the H6 pad for a stock braking system I highly recommend them but they will occasionally make noise.
Old Sep 7, 2010 | 09:58 AM
where would you recommend to go bleed my brake pads?
Old Sep 7, 2010 | 10:37 AM
SharksBreath's Avatar
BANNED
your garage? mechanic? dealer? anywhere?
Old Sep 7, 2010 | 01:59 PM
Bucks13's Avatar
I feel like my brakes are awesome compared to any of my old cars. Never thought they felt weak.
Old Oct 10, 2010 | 10:03 PM
officialTL's Avatar
I just changed my rotors and pads today, now the brakes also do not grab as my old pads. feels very mushy and I have to press the pedal about 50% more than i use too. I like how my brakes were before, so I will try to bleed the brake line, but I did that after everything was installed. Any other ideas if re-bleeding doesnt work???
Old Oct 11, 2010 | 01:06 AM
nasty_nos's Avatar
As you noted, I would first bleed the brakes very thoroughly. One thing I would recommend is going to stainless lines. The rubber stock ones do tend to expand and these lines do not do that. I am not a certified mechanic but can guarantee this will help tremendously unless there is another underlying issue with your braking system. Do not go cheap on the brakes because you will only pay for it in the end. I have found over the years that spending the few extra dollars for a minor upgrade or better part will make you extremely happy and save you in long run. That is my opinion for whatever it is worth being noob 3G TL owner and noob on this site.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
