Brake pad replacement and pushing in calipers
Old Jul 21, 2014 | 05:45 PM
Gocardinals's Avatar
Long story short I replaced my rear pads yesterday and completely forgot to push/compress the caliper in. I put the caliper back over the pads really tight. When I drove the car the service B light came on. There aren't any sounds coming from rubbing but should I take the calipers off and compress them still? Thanks for the help
Old Jul 21, 2014 | 06:17 PM
Turbonut's Avatar
If the calipers are working properly they will "self adjust" so no need to redo.
Old Jul 21, 2014 | 07:12 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Service B is as followed:
Replace engine oil and oil filter
Rotate tires
Inspect front and rear brakes
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system#
Inspect fuel lines and connections#
This is just because your Oil life is at 15% or less and you are due for service. This doesn't have anything to do with servicing your brakes. Still amazed how you got the caliper on without pushing the piston back..
Old Jul 21, 2014 | 07:25 PM
pohljm's Avatar
and new pads.............how is that even possible
Old Jul 21, 2014 | 08:40 PM
nfnsquared's Avatar
OP, are you sure you bought the right pads? I'm with the others, I don't see how you were able to get the caliper back on....
Old Jul 21, 2014 | 09:31 PM
bauermd's Avatar
I have to almost completely compress the pistons back into the caliper when replacing my pads. Not sure how you got your new ones on without any compression. Like stated, make sure you got the right pads.
Unless your rotors are completely worn down. I don't see that as the issue, though.
Old Jul 22, 2014 | 12:09 AM
A SiQ TL's Avatar
unless the pads he replaced still had a bunch of life in them, I don't see how it's possible either.
Old Jul 22, 2014 | 06:32 AM
Turbonut's Avatar
If the rotors were worn, the piston/pads still keep the same pressure as a new rotor, so that wouldn't be the case.
I wondered the same, but thought he might have purchased a different style pad for some reason and the caliper was able to be installed without piston compression.
Old Jul 22, 2014 | 04:32 PM
paperboy42190's Avatar
this looks like its going to be one of those threads that dont really make sense and the OP never comes back to explain
Old Jul 23, 2014 | 08:57 PM
BC2G's Avatar
Registered Big Dog
service B code is based on mileage and tells you general info about what work you should do at this point in the vehicles life. If the pads were just done they dont need to be changed again
Old Jul 23, 2014 | 08:58 PM
I hate cars's Avatar
Agreed with paperboy.
Only possibility I can see is the "old" pads weren't that worn and maybe between a chamfer on the new pad and working the caliper on at an angle which will push the pistons back in anyway, it might be possible.
Regardless, the MID display was a coincidence.
Old Jul 24, 2014 | 03:58 AM
people need to have some respect. If OP wants our time to post replies, please have the decency to answer some of our questions. This is how forums work, all sides need to be responding. If OP is gonna come in here with 1 post and never respond back he is wasting forum space. These kinds of threads dont help anyone, if someone else has this question and finds this thread they will be helpless.
Old Jul 24, 2014 | 09:15 AM
pbook4g5's Avatar
^Or they'll learn that doing a brake job has nothing to do with the "B" service popping up on your display.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Oct 19, 2015 03:26 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
gqdabien
Sep 8, 2015 11:41 PM
nishant11
Sep 2, 2015 10:34 AM
