brake lights dim
Old Jun 3, 2009 | 02:27 AM
victomonie510's Avatar
5th Gear
brake lights dim
hey i just got a 2004 acura tl and i noticed when my friend was driving that the rear lights were dim. when i got home i mashed on the brakes about 10 times and out of 10 2 times were really bright. Any suggestions?
Old Jun 3, 2009 | 11:12 AM
LoveMyTL-S's Avatar
Possible bad or dirty ground wire.
Old Jun 6, 2009 | 01:04 PM
acuratech239's Avatar
Acura Cert MASTER TECH
Brake light switch. I forget what we sell them for, but I'm pretty sure it's under $20. You can replace it yourself, it's easy. Just make sure it's seated properly otherwise your cruise won't work, and/or your brake lights will stay on or come on too late. (Once you see what it looks like, and look at the old one installed, you'll understand what I mean by adjusting it properly)
But really, it is an easy repair
Old Jun 6, 2009 | 07:50 PM
libert69's Avatar
18psi
its the "brake pedal position switch". order it online and install yourself. it goes right behind the brake pedal. the dealer will charge u an hour labor to install and it takes 10 min to do. it snaps into place and has one electrical connection.
i had the same problem a while back.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Rocktman1
Oct 31, 2015 02:33 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
PortlandRL
Sep 14, 2015 12:01 PM
