Brake dust ????
Brake dust ????
I noticed not too long after buying this car that the brake dust tends to build up quickly on the fronts. Well i just put on Axis Hiro (silver) and now i can really see how bad the brake dust is. Any type of pad recomendation for less brake dust? Ceramic pads maybe? Which brand?
That's what I really like about them.. It still looks like I have at least 90% pad life.. When they wear out.. return them for new pads free. Performance is as good / maybe better than the OE pads. I really feel them bite after a good bedding.
Hawk ceramics.. i like them, as well as friends..
edit :: just do a search .. its been covered many times
https://acurazine.com/forums/showthr...=hawk+ceramics
Look for a sticky thread.. there's a few threads on changing the brembo pads and it should be fairly easy. The stock calipers will require 10 & 14mm ratchets I believe.. and channelocks or some other method to push in the piston. Changing brake pads is quick & painless.
I installed a set of Rotex Gold Kevlars three years ago on my '04 manual to escape the prolific dusting. Dusting decreased approximately 80-90%. Since I also own an '05 automatic, it's easy for me to compare the two. And my '04 has no more dusting than my '05. And the very small amount of dusting you get is not black.
GWEEDOspeedo
01-15-2016 10:39 PM
AcuraKidd
09-25-2015 11:18 PM
