Both voltage plug-ins stopped working
Old May 7, 2012 | 04:53 PM
vancity67's Avatar
I use the one in the center arm rest to change my phone and at first i thought the charger was broken and turns out its the other way around and I tried the one thats near the shift knob in the center console and that one doesn't work anymore either. I was wondering how much it would cost to fix that and is it an easy fix?
Old May 7, 2012 | 07:09 PM
ez12a's Avatar
the overexplainer
check yer fuses.
Could be your phone charger shorting it out and blowin dem fuses.
Old May 7, 2012 | 07:21 PM
vancity67's Avatar
how do i check my fuses??
Old May 7, 2012 | 07:35 PM
ez12a's Avatar
the overexplainer
the interior fuse box is located near the hood release near your feet if i'm not mistaken. You might need to look up a diagram to see what fuse goes where. There should be one for accessories or something to that effect.
if it's fuses it's a cheap and easy fix. Easy to diagnose too. Just pull the appropriate one out and look to see if the connection inside is broken. Replace with an equally rated fuse if broken.
mada51589
Jan 9, 2025 04:40 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
theinsvnity
Sep 10, 2015 10:22 PM
