Blinking D light
Old Jun 30, 2018 | 01:14 PM
vafa24's Avatar
Exclamation Blinking D light
Hi,
I have a 2006 tl with 165k km.
I just got the car recently and the d light started to flash.
I got the codes p0700 and p0713.
The transmission shifts fine and the drive is normal.
I am not sure what to do,
any help would be appreciated.
Old Jul 2, 2018 | 10:17 PM
Sadiq786's Avatar
Check your transmission senors and the pressure switches.
Old Jul 3, 2018 | 01:09 AM
csmeance's Avatar
Originally Posted by vafa24
Hi,
700 means trans problem (generic) and 713 means that the fluid got very hot or the temp sensor is bad. Check the fluid, it should be pinkish red! If it's brown, it might be time for new fluid and filter at a minimum!
Old Jul 3, 2018 | 08:06 AM
frankjnjr's Avatar
IMO: If, as you state, the transmission shifts well, two obvious possibilities exist, 1. the fluid, was over-heated, at some point, and needs to be examined, and or changed, immediately! Probably a good idea, to change the filter, as well. 2. The temperature sensor, or it's circuit, has an issue, and needs to be addressed. Checking the fluid, level, and condition, is critical. A low fluid level, can cause added stress, to the transmission, by overheating the fluid.
Old Nov 25, 2018 | 02:41 AM
Brock's Acura TL AT 2004's Avatar
My 2004 TL did the same but started flashing on start up, added ATF and it stopped. Couple days later, after driving 200+ miles.flashing again on start up, added ATF & it stopped ???..
Old Apr 14, 2020 | 11:24 AM
Kevin Cardona's Avatar
4th Gear
help
2009 Acura tsx with 137k miles. I have check transmission and blinking d.
Old Apr 14, 2020 | 11:28 AM
did you check your transmission?
Old Apr 14, 2020 | 11:49 AM
4th Gear
the transmission oil yes.. the transmission itself no. I only have basic knowledge of cars.
Old Apr 14, 2020 | 12:13 PM
4th Gear
anything specific that I should check for in the transmission? I know which part it is. I just don't know what to check!
Old Apr 14, 2020 | 12:35 PM
What did the fluid look like? What did the level look like?
Old Apr 14, 2020 | 01:26 PM
4th Gear
still not dirty and still not past the second mark. I'll check it again to make sure...
sphilli80907
Oct 12, 2019 03:57 PM
DatDereTL
Feb 15, 2017 04:16 PM
keight8
1/2G MDX (2001-2013)
Jun 7, 2016 04:36 PM
ac5320
Dec 20, 2011 10:33 AM
wkkinc2000
Oct 3, 2009 11:24 AM
